HSR finaly installed with fresh motor
Same setup as rick TPI
afr 190's
hsr
355cid 10:1 comp
24lb inj,adj reg
comp cam xr276
Here are some pics. I poste some a littel while back of my powder coated hsr and now I ma glad I did it.
afr 190's
hsr
355cid 10:1 comp
24lb inj,adj reg
comp cam xr276
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Was there any cuting to the stock hood to make it fit? And if so can you show us a picture of it.
Thanks for the replys so far. I plan on going to the dyno on friday to see whats going on. I still have a small pop through the intake a low rpms under 2500 when I touch the gas just a little. I am not sure if it is timing or what. I will try to post some numbers this weekend.
Drew
Drew
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Drew
Drew
boy am I pissed
Well so much for the dyno this weekend. I noticed the car was running like crap today so I took off the valve covers to adjust the valves and wola I find One rocker arm stud pulled out of the head!!!! the other one is loose and spinning around!!! I have one good pushrod and one lost pushrod! I hope it is lying in the lifter valley!!! This is such bullshi!. It is only on number 7. I feel like calling afr and telling to fuc]< off. There is no reason a rocker arm stud should come loose!!!!!!!!
Drew
Drew
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
You did torque the rocker arm studs to 55ft-lbs (if I remember correctly?) when you put the heads on Drew?Did you remember to put Teflon sealant on the studs and then torque them?Whats with you and new motors????
I just know that after this one I am ****in done with motors for a while. This has realy pissed me off. First my 383, then my 406 and now this ****!!!!!! I guess I will just have to pay other people to do my work so I have someone else to blame from now on.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Firechicken86
Aug 12, 2015 10:07 PM
