Best heads for a 383
Old Oct 1, 2002 | 09:17 PM
Trent257's Avatar
im on a limited budget, im building a stroker 383, with holly stealth ram intake, what would be the best heads to use, people have suggested afr 190's, but there 1200, i would like to stay a little cheaper, full head setup to please
thanks
Old Oct 1, 2002 | 11:28 PM
grumpyvette's Avatar
TFS-31500001 Chevrolet: Chevrolet: 302-400 with 4.00 in. or larger cylinder bores, 67cc combustion chambers, with 1.470 in.... $995.95
not quite as nice as the AFR but better than stock chevy thats for sure, available at
http://www.summitracing.com/
Old Oct 2, 2002 | 12:26 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Canfield heads........
Dont know exactly how much cheaper they are but look it up!
Old Oct 2, 2002 | 06:15 AM
gta324
canfields are very good heads but rarely CHEAPER THAN AFR with similar flow numbers, look here,btw starting price = bare,no valves,springs ,etc.
http://www.canfieldheads.com/sbc_2600.html
Ive used these on racing engines they work great! ($1379)
http://www.canfieldheads.com/sbc_2500.html
these are the heads designed for street use($1329)
Old Oct 2, 2002 | 07:10 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
AFR 195 heads are $1250 + $35 shipping from www.martelbros.com or direct from AFR. These are complete with 1.437 springs, retainers, guides, etc.
Old Oct 2, 2002 | 10:57 AM
Matt_91RSTPI's Avatar
The heads are where you can make or break your motor. They are responsable for a majority of the power potential. DON'T SKIMP! Especially on a heavy breathing 383.
How long will it really take you to hold off and save an extra few hundred dollars to get a really good set of heads?
I'd hold off until you can affort to buy a set of heads that won't end up limiting your future power potential. Just my $0.02
-Matt
Old Oct 2, 2002 | 12:24 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
save a little longer for the AFR's. If you have to get a set of heads that are cheap, look into the L98's and port them.
Old Oct 2, 2002 | 02:15 PM
bigals87z28's Avatar
Car: Check The Sig
with a deep breathing 383, wouldn't you go with a head that has a little more breating room then 195cc? im just sayin, i know that a 383 will want a lot more air then a reg. 350... with the HSR.. i would go with somethin with 220cc... i dunno, im just puttin out an idea...
Old Oct 2, 2002 | 02:19 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
AFR 195's work pretty good but if your 383 has a really big cam and a revver, i would go with the AFR 210's. I think the 210's match nicely with a very healthy 383.
Old Oct 6, 2002 | 09:24 AM
JAY87GTA's Avatar
Big runners are nice, but ya got to look at the flow numbers. A big runner flows more air at high lift values, but if your cam doesn't have that much lift than what's the point? For example, I'm just built a 383, AFR 190's, and a Comp cam with 220/230@.050. Lift with 1.6RR's is .544 on both. Now, I looked on CHP's website and compared all the flow numbers. The 190/195 heads outflow all the other's to .500 lift and just barely get beat at .550. What's the point of giving up air down low if I can't use the extra air because my cam doesn't have the lift? Also the bigger runners lose airflow velocity which will hurt the bottom end, losing torque that you need to drive everyday. It's your money though.
Old Oct 6, 2002 | 10:04 AM
u r sofa king we tah did's Avatar
pro action lightning aluminum 200ccs. cheaper and great flow numbers.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
bdads
Aug 24, 2015 06:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
