TPI TPS Voltage Check....
Old Oct 6, 2002 | 10:43 PM
bigjeepinyj's Avatar
I just got finished putting on my TPI and was wanting to check the TPS Voltage. Where do I stick my jumpers in to? I read the writeup on here but dont know if I am going it right. A picture would be great...... Is there anything else that I should check the volts on also? Thanks alot
Old Oct 7, 2002 | 12:30 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
On the two upper connections.....
Old Oct 7, 2002 | 12:32 AM
Do I unplug the wire competly and then check the plug on the throttle body......
Or do I need to jump the wires from the wire pug into the throttle body plug and then put my meter in there?
Hope this makes sense.
Old Oct 7, 2002 | 03:38 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
You have to have jumper wires.........
Just take two thin wires and put them in the two upper connections and then put the stock connector in then start the car and measure on the wires you put in......
Old Oct 7, 2002 | 10:30 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
you don't even have to make a jumpers.just take your meter leads and poke a hole in the wire insulation.as long as you don't get crazy with it it wont hurt anything.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Sanjay
Aug 12, 2015 03:41 PM
