Tools to buy
Old Oct 8, 2002 | 11:27 PM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Tools to buy
Please recommend the Digital Voltmeter to use, by brand name and model number, when setting the TPS. Also, what setting do you put it on? I am no good with electrical, except to connect wires with obvious male / female connectors. A photo with the meter shown clearly would help a lot of us.
Old Oct 8, 2002 | 11:56 PM
Bort62's Avatar
Fluke makes Quite a few nice peices
Ive had no trouble with Mine.
Old Oct 9, 2002 | 08:02 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Any digital volt meter will work just fine. I have a craftsman piece that I like. It's compact, has a rubber shock resistant case over it, and even has the ability to check capacitors.
But when I set my TPS, I use my scan tool to monitor the voltage. Since this is the voltage that the computer sees, I feel it's better to set it by that instead of the voltage at the TPS. Granted they should be the same, but with old wires, it's quite possible that it may vary slightly.
As for what setting to put it on, you want it on DC volts.
Old Oct 9, 2002 | 09:15 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
If you're looking to buy a multi-purpose (and not just car) meter I'd suggest fluke also. Sorry I don't have a model # for you though
Old Oct 10, 2002 | 12:23 AM
86LB9's Avatar
I've got a Fluke 112. Cost me an arm and a leg for, but it was very useful when I was an Electrician. Most multimeters will serve your purpose as long as you don't by the $5 unknown brand. As long as it serves it's purpose measuring Volts, Ohms and Amps.
Old Oct 10, 2002 | 01:00 AM
ZZsmpch's Avatar
I've got more meters than I can shake a stick at. Fluke, sears craftsman, simpson, triplett, etc. They all have the same accuracy, and you don't need to spend a fortune to get a good one. I use the one from sears on my cars, because it was relatively cheap, has a audible continuity buzzer for tracing wires and finding shorts. It's just as accurate as my fluke 87 III DVM's. It even has a thermocouple for measuring temp.
This one is a little different, because the one I use is older, but it does everything you'll need and then some.
http://www.sears.com/sr/product/summ...id=03482175000
Old Oct 10, 2002 | 10:55 PM
abcx09t's Avatar
Thanks, you are all great people taking your time to help a fellow Thirdgen er.
Old Oct 11, 2002 | 02:22 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
http://www.actron.com/cgi-bin/web_st...s.htm&cart_id=
Old Oct 11, 2002 | 12:19 PM
Fastcarjoe's Avatar
get a fluke 98, and I'll call youm when I need to borrow it :hail:
gta892000
Aug 11, 2019 11:16 AM
tyeo098
Nov 30, 2015 06:27 PM
F-body-fan
Sep 17, 2015 12:16 PM
muttracing
Brakes
Sep 6, 2015 08:12 PM
mrdevontay
Sep 2, 2015 08:04 PM
