Will the super ram help me?
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have tf heads and a 218/224 529/533 cam 112 LSA and the LTR setup and went from 14.1 to 13.6 on the stock chip. I am now getting a brand new SR for 500 bucks right from accel will I see a loss of TQ at lower rpms? Whats gonna happen?
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
I believe that with those heads and cam, you will see a reduction in ET. You might lose a little TQ at VERY low rpm, but I think you'll more than make up for it. BTW, I have a 2200-2400 stall and can light up the drag radials at will on the street, I've left 150 ft. marks w/ the drag radials when I tried, I don't think TQ loss will be an issue.
Car: Formula
Engine: 6.0 LSX
my friend works at Wiseco Piston and he has all the connections. he gets everything DIRT CHEAP. He even got it with the polished billet lid for me.
Car: Z28
yes, it will make a difference.
you should check into DIY PROM to set yourself up a chip that works right with it. the stock TPI chip starts reducing fuel at only 4000rpm (because of the rapidly dropping airflow ability of TPI), by 4800rpm it's already off nearly 20%. a superram with heads and cam and whatnot will easily flow up past 5500, so you won't be getting the enrichment up top you need.
you might see a torque loss at very low rpm like the other guy said, but with even a mild torque converter you flash almost immediately to 2000+ RPM. who cares what you lose below 2000?
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Yes, you will notice a big diffrent in the upper RPM's! I went from TPiS LTR to a SR and the diff. was huge... Now its only need tuning and to be blown........
Car: Formula
Engine: 6.0 LSX
Heads TF and 218/224 495/503 112 lsa cam i went from 14.17 to 13.61 still on the stock chip...
no green
Jan 9, 2016 09:22 PM
Dragonsys
Sep 25, 2015 03:51 PM
