what did you use to cut that..
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
aluminum thingy that you dont need after you put on non emission friendly headers...
its the aluminum thingy that the manifold air ducts go into...
any help would be appreciated..
btw..everything else is already disconected..
iroc2nv
iroc2nv
The pipe that goes behind the motor? You could just disconnect your engine grounds and pull it off, although with the right tool cutting would be easier. It will look sloppy leaving pieces in there.
