Ok to block heater valve to intake hose?
Old Oct 10, 2002 | 09:40 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
I did a TB coolant bypass and I was wondering if I can just block the heater valve to intake manifold hose? I assume its alrite because it was used to warm the TB but will I have any adverse affects?
Old Oct 11, 2002 | 01:00 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
The heater hose coming from the front of the intake is the hot water line for the heater as well as the TB. If you bypass the TB, and still want heat, you have to connect that back up to the heater valve. Or you can bypass the heater valve too and run it straight to the heater core.
If you want to eliminate the heater too, feel free to route the line from the intake straight into the return to the radiator. If you want to block it all together, pull your t-stat and drill a few bypass holes.
1992 Trans Am
May 10, 2023 07:19 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
1985chevydude
Aug 20, 2015 12:29 AM
