Nead a good cam for TPI
Im rebuilding a old style engine (not with roller cam) and Im going to put a TPI on it , the engine is going to be all stock put I would like to put in a better cam, what cam would be a good one for a daily drive?
JD
JD
Thanks fastvetteTPI84
I was thinking about260AH-14 cam from them but I will see what numbers that cam has, is it not a little to big (268*) for a street car?
What power band does it have? how much mpg do you get?
JD
JD
hello, is it a 305 or 350? i have an 86 iroc with a 305 tpi. all stock, except motor bored .030, and a comp cam with lift of .444 on both intake and exhaust. i like it pretty good. comp cam says its for a 305/350 tpi. when i received the cam, the box said 350 tpi, i quickly called the 800 number for comp cams. they said the cam is for both 305 and 350 tpi. its what i use, good vacuum and idle (thats what i wanted...nothing too crazy) best of luck, tom....if you want, i may be able to track down the comp cam part number.
Thank you for that info Tom!
It is a .030 over 350 so it is 355, Im like you I dont want anything to crazy because I have that in a nother car I have just looking for something that would do good as a daily driver.
JD
PS it would be nice to see what cam you have.
JD
jd, it is a comp cam, computer compatible cam. the one i got is 1200-5200 rpm range. dur .050 is 212/212, lift is .444 on intake and exhaust, lsa is 112. they offer another cam with the following specs... 1500-5500 rpm range, dur .050 212/intake, 218/exh, lift is also .444 on intake and exhaust, lsa is 114. best of luck, tom.....you may want to call some cam companies to see what they suggest.
I used a cam by general kinetics(machine shop installed when they did short block.
216 @ .050 lift .454 lift with 1.5s 110 lsa. Idled like stock made great power from idle to 5500. This was a hydraulic non-roller.
I think the 268 would be good (I think it is a 219 @ .050).
Best advice call the cam company they do this for a living.
Sanjay
Aug 12, 2015 03:41 PM
