AFR 190 heads
Old Nov 9, 2002 | 10:01 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
AFR 190 heads
I just checked out their site. Can anyone tell me the difference between angle plug heads and L98 angle plug heads? I may have solved the problem that I've been having. I have an L98 but I think they *may* have sold me the regular angle plug heads. If so would my intake manifold match up? Thanks.
Danny T
Old Nov 10, 2002 | 02:54 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
If you have an L98 than "L98 angle plug heads" is what you want. Simple.
Old Nov 10, 2002 | 02:58 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
BTW, your intake manifold bolt pattern has nothing to do w/your plug angle happens to be.
Old Nov 10, 2002 | 12:07 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Obviously I need the L98 angle plug heads but they also carry angle plug heads that aren't L98 specific. Do you know what the actual difference is? That's what I'm trying to figure out. Thanks
Danny T
Old Nov 10, 2002 | 08:49 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
The reason you'd want L98 angle plugs is so if you want to use headers like SLP or Edlebrock they would fit and clear the plugs.
Old Nov 10, 2002 | 09:13 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
OK thanks. So you're saying that the same intake manifolds would work on either head?
Danny T
Old Nov 11, 2002 | 01:56 PM
wataru's Avatar
No you want the L98 angle plug heads. If they sent you the wrong ones, send em back.
Old Nov 11, 2002 | 06:56 PM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Danny T
When ordering the heads specify that you have a TPI intake manifold so you would receive the correct bolt pattern.
The thing that I found out about AFR, the company, is that when they receive an order for specific heads, they make them from scratch. So be prepaired for a 2-6 week waiting period. I waited 6 weeks for mine. It doesn't matter if you order from AFR or from one of their dealers. The wait depends on how backed up they are but buying from a reseller is considerably less expensive, in most cases.
Old Nov 11, 2002 | 09:58 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
OK, I guess I should have elaborated more from the beginning. The heads were installed over a year ago at a shop because it wasn't something I was willing to tackle at the time. I bought the heads from TPIS, they are their Stage I AFR-190 heads. At the same time I was also switching to the Super Ram intake manifold. The first mechanic didn't mention a problem but it turns out he was an idiot (for other reasons). The next shop asked where I got the heads from because the intake didn't seem to match up perfectly. I haven't really driven the car much in the past year or so because I bought a truck but I have been wondering about this intake problem ever since. I didn't continue to research it at the time because I was running low on funds. I guess I'll start with a stock manifold to see how it matches up with the heads then go from there. If it turns out I have the wrong heads then it may be easier to just get an intake that matches than to but another set of heads.
Danny T
Old Nov 12, 2002 | 02:12 AM
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I’m not sure what you’ve ordered and how it fit but if you start out w/a stock TPI set-up, then any aftermarket parts, you ordered to replace the stock parts, should fit!!!
The only difference I can think of is that 85-88 TPI is slightly different from 89-92 TPI . Someone correct me if I’m wrong as far as the right years.
You should really do some “Archives” research.
Later
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
89mulletbird
Aug 12, 2015 07:08 PM
