fuel pump voltage
Old Nov 12, 2002 | 04:55 PM
pjw67's Avatar
fuel pump voltage
My car wouldn’t start today. I immediately looked at my fuel pressure gauge, which was at zero. I parked it last night and it was running fine. I can hear my fuel pump run when I turn the key. I plugged in my scanner and I am getting zero volts when I turn the key on. When I crank I get around 12 or so volts on the scanner. I checked the fuse at under the hood and it is fine. I also unplugged the fuel pump and sender under the trunk and am only getting 6.2 volts. I know that is low, but should it turn the pump? Why would I get 12 volts on the auto xray and only 6 at the tank? Any help?
Old Nov 16, 2002 | 07:31 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Try running a different wire just to test if it makes a difference and if it does then you'll know that your original line may be bad. But, did I understand right about the fact that the fuel pump primes when you turn your ignition on? If it does I would imagine it should run, but don't quote me on that! I hope it helps.
Old Nov 20, 2002 | 09:07 PM
jjg's Avatar
jjg
I am having the same problem I dont hear my pump though i am getting 12 volts at the relay but when i trace it back i get like 6 volts by the connector back by the rearend
What is causing this???
Old Nov 20, 2002 | 11:55 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
More than likely, dirty contacts on the pump relay or a corroded wire dropping the voltage.
Old Nov 21, 2002 | 12:02 AM
pjw67's Avatar
I ended up just running a new wire to my pump. The contacts didn't look bad at all, but I think the wire is probably shot somewhere along its path. It works fine now with a new wire.
Old Nov 21, 2002 | 12:08 AM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Does that mean that the car is running?
Old Nov 21, 2002 | 12:09 AM
pjw67's Avatar
yes sir,
runs fine now
Old Nov 21, 2002 | 12:17 AM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
GREAT
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
89GTAOz
May 16, 2020 09:31 AM
92camaroJoe
Aug 13, 2015 06:07 AM
