SFI for 18* heads
Old Nov 13, 2002 | 06:58 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
SFI for 18* heads
Hey guys,
I was wondering if anyone has a quick link to some fuel injection systems for 18 degree heads.
I ahve been looking around but have not found much.
Thanks:hail: :hail: :hail:
Old Nov 13, 2002 | 07:51 PM
Bort62's Avatar
Motec, FAST, Speedpro...
All should work fine on 18* heads.
Friend of mine w/ a GN w/ edlebrock 18* Heads uses a Motec ECU and just ran a 8.57 @ 169 on a 1.4 (soft lauch) 60' lol
So it should workout for you...
Old Nov 17, 2002 | 03:34 PM
Trux's Avatar
Transmission: t-56
Thanks, =)
Been awhile since I have checked my email been busy with college and stuff.
Thanks for the reply I will look up for those brands.
Thank you:hail: :hail: :hail:
Old Nov 18, 2002 | 12:35 AM
89ProchargedROC's Avatar
any fuel injection system will work with 18* heads......**** you could use the stock GM stuff if you wanted
The problem would be the intake....you would need to have a 18* intake converted to fuel injection
Old Nov 18, 2002 | 03:16 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Hogan's will make you an intake (they make a couple of TPI intakes (VERY expensive though!!) But, they're pretty bada$$ !!!
Old Nov 18, 2002 | 03:20 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Sorry bout that, here's the link:
http://www.hogansracingmanifolds.com/
Old Nov 18, 2002 | 09:29 AM
hogan's is an option, but not necessary. Get a cowl hood and a normal carb style 18* intake and convert it, it will be cheaper
Old Nov 18, 2002 | 12:03 PM
Trux's Avatar
Transmission: t-56
Agg
I know carb would be cheaper right now but I wanted to go fuel injection for alot of reasons
Old Nov 18, 2002 | 12:37 PM
no, you dont understand
i mean you take a carb style 18* intake and convert it over to fuel injection
like what i did to my victor junior intake:
here
Old Nov 18, 2002 | 05:30 PM
Trux's Avatar
Transmission: t-56
WOW
I actually thought about that but was thining hownI could g3et a computer that would work right if I converted it. Your setup looks very nice, great job.:hail: :hail: :hail:
How much time did that take?
what computer are you using?
thanks:hail: :hail: :hail:
Old Nov 18, 2002 | 07:04 PM
i had a friend do the conversion and milling for me
Cost me $350 for the conversion and milling plus i supplied the fuel rail and bungs which were $60 total
You could run a 4 barrel type EFI throttle body on top and have no issues with the stock computer
i am running an aftermarket FAST system with wb02 sensor for my twin turbo motor
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
