problem tpi
Old Nov 20, 2002 | 10:53 PM
fastvetteTPI84's Avatar
problem tpi
hey guys im helping a friend with his 91 tpi firebird and it has an odd problem it starts just cold just fine after a few min of running or driving it starts to run rough and then shut off no start after that , at that time there is no spark if you let it cool off a while like 20-30 min it starst back up no prob no codes or data from the scan tool that looks off , now it has the small dis and external coil
im assuming its one or the othere being that it gets hot and dies cools off and works again untell it gets hot again
any ideas on this prob would be helpfull thanks
Old Nov 21, 2002 | 09:36 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
maybe an ignition module overheating. never had it happen but I imagine it could.
Old Nov 21, 2002 | 11:46 AM
ok ignition mod , didnt think about that thanks , would you know there that is located on that car with the small dis hei . thanks
Old Nov 21, 2002 | 12:17 PM
89BlueTA's Avatar
It is located under the dist. cap.
Maybe the coil overheating??
Try touching those things when it will not start due to heat and see if they are very hot.
nick
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
jbd1969
Aug 17, 2015 07:06 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
