Does your timing jump around at idle like mine?
Old Nov 25, 2002 | 04:32 PM
88TAJeff's Avatar
Car: 88 T/A
with the est wire connected? I'm chasing a idle/ part throttle problem and I just want to know if it's normal.
THANKS!
Old Nov 25, 2002 | 04:42 PM
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Yes, and with the wire disconnected, it should be steady (at least mine was when I was timing the car last night).
Old Nov 25, 2002 | 04:45 PM
88TAJeff's Avatar
Car: 88 T/A
well, with the wire disconnected, it's rock steady. But with it connected, it jumps all over the place even at part throttle. Is this normal?
Old Nov 25, 2002 | 04:55 PM
DURTYBIRD's Avatar
Last night when the wire was connected it would bounce around between 8* to 10* of variance or so... Disconnected it was steady.
HTH...
Old Nov 25, 2002 | 04:56 PM
88TAJeff's Avatar
Car: 88 T/A
Thanks 91....
HTH???
Old Nov 25, 2002 | 08:03 PM
92TRANSAMWS6's Avatar
Originally posted by 88TAJeff
HTH???
"Hope This Helps" or "Hope That Helps"
Old Nov 25, 2002 | 11:34 PM
88TAJeff's Avatar
Car: 88 T/A
thanks, I figured that out just after I posted that, Duh...
Old Nov 29, 2002 | 09:29 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
mine did then i got a new timing light and... woohoo! timing is consistant now.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
Wade787b
Sep 29, 2015 01:15 PM
