Cant set minimum air, why???
Old Nov 26, 2002 | 01:31 PM
SillyWabbit's Avatar
Car: '91 Formula
I went through the procedure as outlined in the tech articles here as well as the procedure in my Chevy TPI book, and I can't make it happen. I jumper terminals A & B in the ALDL with the ign on, then wait, disconnect the IAC from the computer, and then try and start the car. Only problem is the car won't start under those conditions. It turns over, stumbles a second or two, then dies. Seems like this could be a problem unto itself. Any ideas?
Old Nov 26, 2002 | 01:41 PM
Jza's Avatar
Jza
Open up the screw enough to keep the car running when you start it and set it from there.
Old Nov 26, 2002 | 09:42 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
You'll have to have someone pedal the accelerator to keep the engine running while use adjust the throttle plate adjusting screw. Or as written above, open it up more than needed, then adjust closed after cranking.
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
