TPI TPS voltage/cold stumble
Old Nov 26, 2002 | 09:18 PM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Axle/Gears: 3.23 posi 10 bolt
Can any one tell me the voltage setting for the TPS on my '85 Z-28 w/ stock 305 TPI motor
I am also experiencing a dead stumble when taking off (even gently) with the engine cold. This is my first TPI engine so I'm learning as I go. Thanks, Randy
ranbo108@juno.com
ps the S-10 Blazer in the pic is for sale
Attached Thumbnails TPI TPS voltage/cold stumble-image2x1.jpg
Old Nov 26, 2002 | 11:53 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
According to my manual (it doesn't specify years only TPI) the TPS should be set at .54 volts with a margin of .075 volts either way. These readings are taken between the middle and bottom pins.
Old Nov 27, 2002 | 12:32 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
Old Nov 27, 2002 | 07:05 AM
Ranbo108's Avatar
Car: '85 Z28 TPI
Engine: 305 F vin
Transmission: 700
Thanks Guys
That's just what I was looking for! You guys are made of gold!!
Old Nov 29, 2002 | 02:08 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Re: Thanks Guys
The F-Bodys I think are the same in this department so this should hold true. Typically you can set your TPS as high as 0.68v at idle before throwing a code. If it does throw it, back down a little at a time. I think the computer tosses the code if it sees higher than 0.68v at less than 2000 RPM. I found on my Corvette that it gave ever so subtle gains in throttle response. It causes the car to idle about 100-200 RPM higher, but I don't mind.
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
