quickest way to remove tpi engine?
Old Dec 2, 2002 | 12:58 AM
Kandied91z's Avatar
alright, i've got a 92 Z that i need to remove the engine and i need to do it rather quickly. what's the best way to do this knowing that no wires are to be kept and the car is laying on it's frame.
is it possible like this, could it be done in say less than an hour.......?
Old Dec 2, 2002 | 11:52 AM
Morley's Avatar
Dynamite. TNT, Nitro, comealong......... An hour or less? Nope, not without explosives.
Old Dec 2, 2002 | 12:44 PM
Kandied91z's Avatar
so your telling me that two people with the right tools and no need to save anything other than the long block can't pull the engine in less than an hour?? i find that hard to believe, guess i won't know til i try it then.
Old Dec 2, 2002 | 12:48 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
If you don't need to keep anything, i would say it would be close to an hour! If like you said, you have the right tools. Just cut everything you possibly can and undo the motor mounts and you should be good to go. Oh yeah, take off the tranny or take it out with the car, its up to you. You won't need to be careful and you will not need to label anything so it should be pretty simple and straight foward! What are you doing, planning on stealing a tpi car soon? j/k
Old Dec 2, 2002 | 01:05 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Sounds like it's already been stolen, LOL!
Old Dec 2, 2002 | 01:16 PM
Morley's Avatar
If it is sitting on the frame as you said it will make the tranny a real pain to unhook. I would guess more on the order of 2-3 hours.
Old Dec 2, 2002 | 05:03 PM
360Iroc's Avatar
thats what i was thinking
Old Dec 2, 2002 | 06:25 PM
Boosted GTA's Avatar
Any particular reason you have to remove the motor in under an hour, and not care how you do it???
Old Dec 2, 2002 | 07:48 PM
Bort62's Avatar
Remove the two motor mounts, remove the distributor.
Remove the tranny cooler lines and fuel lines, cut all the wires.
unlatch the transmission mount and shift linkage, and pull.
Should come right out. Im pretty sure I could do it in an hour with the right friend.
Take the tranny out once you have it out, or just take it with ya.
I won't tell
Old Dec 3, 2002 | 12:26 AM
Kandied91z's Avatar
one car the harness is gone and not the engine??
second one the harness is completely hacked up along with the rest of the main lines connecting the pieces. afterall the car is laying on it's frame with nothing but a frame and the driveline.
ever work out in 10 degree winter weather with a nice snowfall.........i want in and out as quick as possible. i'm sure you guys can understand that.
Old Dec 3, 2002 | 09:10 AM
Jza's Avatar
Jza
Three words:
<u>Twenty-four Volt Sawzall</u>
Unless you have access to power. Then it's
110V Sawzall
It is in a junkyard or something isn't it?
Old Dec 3, 2002 | 12:56 PM
Bort62's Avatar
There is that...
We Removed the engine from my Wrecked Firebird, AND installed it in my friends Corvette AND got it runnin all in 5 hours. haha.
That Included Cutting the front sheetmetal off at the Firewall With a Sawzall. (It was wrapped around the engine)
If it is laying on the ground, You are going to have a helluva time Getting to the tranny mount.
Use the Hoist to pick up the car and slide some old wheels under it Junkyard style.
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Sep 3, 2015 10:56 PM
R3500
Aug 17, 2015 12:16 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
