crane compycam 2030
Old Dec 5, 2002 | 01:01 PM
devilfish's Avatar
crane compycam 2030
crane compycam 2030 ....duration 264'/274' lift 423'/446'
How is this cam with my 6spd tpi corvette? Is it a good cam with asm runners accels base, headers. Or is it a "miniram" cam?
Old Dec 5, 2002 | 01:14 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Its a small cam I dought if it would be worth the time to swap.What year is the block?flat or roller lifters?
Old Dec 5, 2002 | 01:16 PM
devilfish's Avatar
roller 1991
Old Dec 5, 2002 | 05:27 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Think about the ZZ4 or GM HOT cam the ZZ4 is better for the TPI but if your thinking of changing the intake later to Super,Mini,or Stealth ram you really need something bigger.
Old Dec 5, 2002 | 06:14 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
The 2030 is fine if you don't feel like messing with the PROM, the LT4 hot cam will need some chip burning as it is fairly aggressive cam. The LT4 hot cam will be limited due to the flow capabilities of the stock TPI unit.
Old Dec 5, 2002 | 06:56 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
the cam u are talking of is a non roller cam and besides its smaller than your stock cam
Old Dec 5, 2002 | 07:11 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
http://www.cranecams.com/master/apps/chevy37.htm
The powermax hydraulic roller 2030 cam is smaller than the factory 91 corvette TPI cam? I don't think think its smaller than the factory cam. Crane does however offer this 2030 cam in a flat tappet form that runs 139.99 from jegs. The roller version is 259.99 from jegs.
Old Dec 5, 2002 | 07:23 PM
86IROCTHD's Avatar
Car: 88 Trans Am
i am sorry i didnt not realize they made a roller vesion of that cam i bought the flat tappet
Hotrodboba400
Dec 10, 2019 07:07 PM
TexasMaro
Sep 15, 2015 06:50 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
camaro71633
Sep 1, 2015 10:24 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
