Any solid proof on Rev Kits?
Old Dec 9, 2002 | 08:01 PM
scorp508's Avatar
Car: Corvettes
Engine: Modified L98 & LT5
Transmission: DN 4+3 & ZF6
Axle/Gears: 3.07 & 4.10
Hi everyone. Does anybody have any solid proof of helping keep HP levels up with the addition of a rev kit on their engine?
My 350 is currently apart and I'm considering adding one when I put it back together in the next couple of weeks. It is a superram'd 350 with the 219 cam and 1.6 rockers. So far I have been shifting at 6000, but if I could squeeze a few hundred more RPM out of the powerband I'd be thrilled. I don't seem to have any valve float, but better safe than sorry is always good.
Old Dec 9, 2002 | 09:44 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I would also like to know this. And what kind of difference if any at all would it make if you have some serious valve springs.
Old Dec 10, 2002 | 06:37 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
I've run the AFR rev-kit ever since I put on my AFR
heads.. In my case, the ref-kit didn't help the valve
bounce that was occuring with the STD AFR 1.437"
springs over 6000rpms.
In hindsight, I believe these are just bad springs and
should have been avoided.. (AFR actually has a
disclaimer about them online now...)
So the rev-kit can help as a spring ages or vary
in tolerances, but the kit shouldn't be used to band-aid
inadequate valve springs...
mike
Old Dec 10, 2002 | 07:59 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
... as in my case
When it approaches 6500rpms all I can think of is Scotty from Star Trek. "She can't take it anymore captain. She's gonna blow!"
Tim
Old Dec 10, 2002 | 09:48 AM
PonyKiller87's Avatar
Car: 87 Iroc Z28
Engine: 355 TPI
I was wondering about the Rev Kits too, I am upgrading pretty much everything on the heads this winter (rockers, springs,rods...) and I seen the Rev Kit but wasnt sure if I needed it or if it would actualy help anything. If I get them it would be the comp cams kit being that all the other parts are comp cams anyways. Anyone know how hard they would be to install ?
Old Dec 10, 2002 | 02:39 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
If you look at the AFR site you will find the REV kits are only really good on all out race applications that run in the 6000 to 7000 range. You would be far better to just run good valve springs to match you application
Brian
Old Dec 11, 2002 | 12:41 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I think the rev kit is a good idea for anyone who races their car. I used a rev kit on mine last season. Granted I was using a solid roller cam, 657/600 lift and buzzing to around 7000 but, I had a lifter go which bent a pushrod, but the pushrod stayed inside the spring of the rev kit.
They are not too hard to install and if the motor is apart anyways, I think it is good insurance.
Old Dec 11, 2002 | 02:09 PM
Fastbird is right on the money. They are not needed for a street car under 6000 rpm but it can't hurt if you chose to use a kit on a street car.
Brian
gta892000
Aug 11, 2019 11:16 AM
Stroopwafel
Sep 11, 2015 06:38 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
