Starting Problems
Old Dec 9, 2002 | 11:02 PM
LiQuido0's Avatar
Starting Problems
Hi I got a 1986 5.0L TPI Trans Am, when I start the car it dies imediatly, but when I disconnect the MAF it starts and runs on the default, so i bought a new MAF, still has this problem, I just replaced the sparkplugs/wires and the fuel filter and it is still doing the same thing, anyone have any ideas on what I could try next ?
Old Dec 10, 2002 | 12:17 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Did your check engine light come on?
Old Dec 10, 2002 | 10:20 AM
LiQuido0's Avatar
yes, my check engine light comes on
Old Dec 10, 2002 | 10:54 AM
LiQuido0's Avatar
Ok i tried adjusting the torx screw on the throttlebody and when i had it loosend almost all the way down it would start and stay running maybe 2 seconds longer then it originally did, also I was looking at the "Air Idle Control" article in Tech Artics, and i dont know where it says for me to do this Take the paper clip and open it up and form it into a big "U" shape. Insert the clip ends into the ALDL in the 'A' and 'B' pins
Anyone know what its talking about ?
Old Dec 10, 2002 | 11:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
doing the paperclip thing allows you to ground the computer. This will then give you your trouble codes through the SES light.
Old Dec 10, 2002 | 11:24 AM
LiQuido0's Avatar
Ok so what should I do then ? I cant figure out why the car dies right away.
Old Dec 10, 2002 | 11:45 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
Check this out. it's there.
Old Dec 10, 2002 | 11:58 AM
LiQuido0's Avatar
what section should i be looking for
Old Dec 10, 2002 | 01:57 PM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Try this link:
https://www.thirdgen.org/newdesign/f...gen.shtml#misc
and read the first question: "How can I display the error codes from a Service Engine Light?"
This will explain how to read it too!
Once you get a specific trouble code, come back and ask with that number, it will make sense later. Tell these guys here what the number is and they will help you get it fixed.
Old Dec 12, 2002 | 11:35 AM
LiQuido0's Avatar
Hey does anyone know what Fuel Pressure PSI I should be reading ?
Old Dec 13, 2002 | 12:41 AM
IROC212's Avatar
Car: 1986 IROC
Engine: 355 Tpi
Axle/Gears: 9 Bolt 3.27
35-42 stock, hey check out the MAF relay, my 86 did the same thing. Replaced the power and burnoff relay....kosher after that
hope this helps.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
