Accel Runners
Old Dec 12, 2002 | 05:11 AM
IROC_Vert's Avatar
Car: Camaro IROC-Z Convertible & Camaro
Transmission: Auto & 6 SPEED
Axle/Gears: 2.73 & 3.42
Accel Runners
I can get a good deal on these accel runners ( they were part of a LPE StreetRam setup part no. 74130), unfortunatly the guy who wants to sell them doesn´t have a clue from what engine they came off... he doesn´t know if they have the cold start injector.
Does anyone of you know, or can anyone tell by looking at the picture if they have the cold start injector, because I would need one.
Thank you,
Alex
Old Dec 12, 2002 | 07:32 AM
IROC_Vert's Avatar
here is the picture of the runners
Old Dec 12, 2002 | 07:49 AM
87GTA Runner's Avatar
Car: 87 GTA
See the tab in the upper left of picture, by the EGR runner. The bigger hole is for a cold start injector.
Old Dec 12, 2002 | 11:08 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
you can still use those if you have an 89+f-body.you'll just need to plug up the cold start injector hole.
Old Dec 12, 2002 | 12:48 PM
Bort62's Avatar
To Clarify what these guys have Implied but not Directly stated..
YES. Those Runners have the Cold start Injector provision
Old Dec 12, 2002 | 01:11 PM
IROC_Vert's Avatar
thanks to everyone for their answer, thats exactly what I needed to hear
Old Dec 12, 2002 | 01:38 PM
IROC_Vert's Avatar
I forgot one thing though, the guy who is selling them isn't sure if they come with all the bolts ... anyone know what bolts and gaskets I need in order to be able to use them ? (part No. 's appreciated )
Old Dec 12, 2002 | 02:06 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
you can reuse the bolts out of your existing runners i believe. and for the gaskets you could go to a place like NAPA or Autozone and get stock gaskets. however i reccommend Accel's gaskets, they have larger holes and will fit those runners openings better. you can find teh part #S for those gaskets on accel's website
by the way you may need to so a little port matching of your stock plenum and base to get the most gain out of those runners.
Old Dec 12, 2002 | 11:43 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
You can order the high flow gasket set from LPE. Part # is LN00010, cost $19.95. I don't mean to belittle you, but you not being able to easily tell that these runners have the ninth injector hole leads me to believe that you are not mechanically in tune with your vehicle. I recommend you take it to a shop to have the plenum and lower intake removed and ported to match the gaskets and re-installed. Or buy a good illustrated manual.
LPE
Old Dec 13, 2002 | 08:35 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Dude, he only has 42 posts, give him some time. Besides, he may just not know about TPI or EFI period.
(pssssst, thats where we come in)
Linson
Oct 24, 2025 02:00 PM
Fanatic1074
Oct 3, 2022 05:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
