replacing candy *** stock intake ducting
Old Dec 17, 2002 | 11:18 AM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
on my GTA i had a problem getting enough air in , i replaced the stock tiny rubber elbow with a 96 LT-1 piece (need the one w/o silencer) flipeed 180 deg then the MAF the i used two 4" mandrel 45 deg. pieces (requires alittle creativity, cuttining, & welding the 2 bends together) ground down the seam where i welded painted it semi-black slid a k&n for a turo diesel ram 3500 on the end and whala! only draw back for the purist out there is that i drilled out the spot welds and removed the lower apron panel where the the filter canister resided so the filter could drop down in there.
here my .02 i've got my maf housing to 73mm i.d. which is more than enough for me with out arguing the benefits of SD with 1/2 the members on this board or hacking up harness and burning 50 chips for nothing, but what was also killing me was small stock stuff the LT- 1 cars run large ducting with the same size maf +or- a few mm and can make great power with only adding a k&n FIPK (filter and hi-flow tube to maf)
with my old in stuff ( stock elbow >maf>3" pipe> cone filrter) my car made a hissing/sucking noise from the filter similar to project magnum.
Old Dec 17, 2002 | 02:04 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I get that sucking/hissing noise also. I can hear it inside the car at idle. I used 3" plastic pvc tubing from ace hardware. Couldn't find anything in 4" that would fit between the radiator support and the a/c compressor.
You got some pics?
Old Dec 17, 2002 | 02:45 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Replacing it with the 88-89 intake ducting with a K&N on the end would probably have been a lot easier and just as effective.
But... with an open element like that, you are going to hear a "sucking" noise that you don't hear with the stock enclosed air filter.
Old Dec 18, 2002 | 01:33 PM
quickL98's Avatar
my Z has an open element conical filter and it doesnt make that hissing sound... 3" pipe would work on a stock motor i bet. i dont know how to post pics....i know i know....the pipe i used was nelson industial #89104a
Old Dec 18, 2002 | 07:01 PM
Jim85IROC's Avatar
When I replaced that ducting on my 86 firebird, it had that hissing sound until I put the paper air filter back on. My friend's celica did it with his custom intake too.
Old Dec 18, 2002 | 10:12 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
That hissing sound means that the engine is sucking in plenty of air, do you really want to get rid of it?
I liked it (the hissing) when I put a cold air intake on my 91 3.1... but to each his own.
Old Dec 19, 2002 | 09:54 AM
quickL98's Avatar
that hissing sound could also be equal to a track and feild athlete trying to breath through a cocktail straw.... get what i mean , also that set up i had on my GTA ,i slapped it on my 94z actually all i replaced was the the pipe section from MAF to filter i put the 2.75 I.D. aluminum pipe with cone filter on there, the car made a audible sucking sound the Z actually ran sluggish, so i put the OE front tube back on with a larger filter i had laying around and got my power back, with no noise either go figure. all i know is this with out the ducting in front of the MAF it runs good i put the **** on it hisses and stubles when i gun it. with the bigger tube i can flow enough air for the car next to me, it not even realy about that its volume i need , when i nail it that old tube couldnt move enough air through there fast enough to keep that big *** plenum full, small **** might work on the mild LTR motors that breath past 4700 any way. compare the intakes, thats what got me hot on putting on the LT-1 elbow and using the same size or slightly larger intake ducting, an lt-1 isnt much bigger that an L98 put everything lead to it and after is which odviously helps move a larger volume of air as i proved to myself in the above.
i post some pics soon
any suggestions with a iMAC
Old Dec 19, 2002 | 09:57 AM
quickL98's Avatar
Originally posted by quickL98
volume i need , when i nail it that old tube couldnt move enough air through there fast enough to keep that big *** plenum full, small **** might work on the mild LTR motors that breathDONT past 4700 any way. compare the intakes, thats what got me hot on putting on the LT-1 elbow and using the same size or slightly larger intake ducting, an lt-1 MAF isnt much bigger that an L98 but everything lead to it and after is which odviously helps move a larger volume of air as i proved to myself in the above.
ileft out some words see caps
Old Dec 19, 2002 | 10:31 AM
hndsm17's Avatar
switch the stock intake on the t/a with the ones from the 90-92 marows that intake it one of the less restrictive ones:lala:
Old Dec 19, 2002 | 10:38 AM
quickL98's Avatar
the set i have now is fine but i dont have camaro
1992rs/ss
Jan 31, 2025 05:10 PM
TheExaminer
Aug 26, 2015 04:59 PM
marcusaw
Aug 10, 2015 08:13 AM
87350gtanj
Aug 8, 2015 10:32 AM
Leggman1
Aug 6, 2015 04:15 AM
