lt4 hot cam kit + miniram
Old Dec 20, 2002 | 02:34 PM
devilfish's Avatar
and ported alu heads.
Anyony used this combo??
Old Dec 20, 2002 | 02:52 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
I ran the MR and LT4-HOT cam on my
ZZ4 (unported Alum L98 heads)
http://www.eecis.udel.edu/~davis/z28...MRwebpage.html
shows the dyno..
Made nice power up to 6500rpms..
It's probably not the phatest cam you can
run, but it's very streetable and makes good
power up where the MR shines...
mike
Old Dec 20, 2002 | 09:37 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
If you want to run a MiniRam then put a real cam in it. The HOT cam in puny for the MiniRam.
Mike doesn't know what he's talking about ... go match power.
Tim
Old Dec 20, 2002 | 11:10 PM
kevinc's Avatar
Car: 1982 Z28
I run a HOT cam presently and am happy, but plugging around in DD2000 I notice the Comp Cams #305 cam will make significantly more HP. Next time I'm in the engine I'll likely swap.
Old Dec 21, 2002 | 07:37 AM
Skweezn87's Avatar
Car: 78 Vette Pace Car (730 ECM MOD)
Engine: 427 SBC
LT4 HOT cam = --><-- cam... Get something in there that will run...
Old Dec 21, 2002 | 05:36 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Damn, this thread makes me feel like a *****! LOL I got the Hot cam for my fastburn crate motor and miniram set up thinking it would be a good match up. I got this one b/c people were having good results with it at the time with the miniram. I was going to go with one of TPIS' cams but when i brought up the idea of the Hot Cam to them they had told me that it would be a little bigger than the one they dynoed with the fastburn set up which made 460hp and 435lbs/ft. We'll see how much bull that was when i get to a dyno tune. I am hoping for similar results to the fly wheel. The motor is not running yet but i am not about to go and and pull the cam just b/c of this. Its still a nice cam IMO but there is definately room for improvement! It is by far not as "HOT" as it should be. Any other recommendations for a future cam for me? Maybe next fall i'll pull it out and work the heads too, just to freshen it up i guess! Thanks for any help-Bryan
Old Dec 22, 2002 | 07:09 AM
TRAXION's Avatar
The key here is to pick a big cam that will still leave you with enough piston-to-valve clearance. I'm running 0.550" lift with a stock 0.030" deck and 60cc chambers and have plenty of clearance. If you are running 58cc chambers then you may be forced to pick a smaller cam in order to have enough P-to-V.
Tim
Old Dec 22, 2002 | 12:23 PM
Skweezn87's Avatar
Engine: 427 SBC
Ah NO need to worry about it... PPL have had GREAT results w/ that cam... I was just giving Mike a hard time...
Gotta keep him on his toes... LOL!
Old Dec 22, 2002 | 03:45 PM
e-man's Avatar
Car: 89 formula
Engine: 383
Alot of the LT1 guys like the comp 12-432-8 and 08-306-8 http://www.compcams.com/information/...umber=12-432-8 http://www.compcams.com/information/...umber=08-306-8 They say that 12-432-8 is better because of more agressive lobes and you dont have to spin it as high.This summer Im switching to 432 the hot cam is just to mild.
Old Dec 22, 2002 | 04:52 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks guys! I am sure i will be plenty happy with this set up for a while compared to my old 305. Like i said, there is always something bigger and badder to be done. Time and money are my only restraints! Thanks for your time-Bryan
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
80s Poncho
Aug 19, 2015 06:45 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
