52mm or 58mm?
Old Dec 22, 2002 | 07:22 AM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
52mm or 58mm?
Im looking for a new trottlebody. Should i get the 52mm or 58mm. The only mods on my car is hedders and 3 inch exhaust and no cat.
Old Dec 22, 2002 | 09:16 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Re: 52mm or 58mm?
If those are your only mods, on a 305 even. THen I would not bother putting either on your car until you get the complete internals to breath and work with such a mod. Try a search on this topic and see what you come up with. Alot of people ask this same question and get the same results...don't bother! But to each ther own, but I think it would be a waste of money for you at this time. You need to open up the intake itself. the heads, some bigger injectors, higher fuel pressure. I would cahse after some of these mods before atttempting to up the size of the throttle body. HTH
Old Dec 22, 2002 | 09:45 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Re: Re: 52mm or 58mm?
i second that
i've seen test where they put a 58mm TB on a stock 350 and they lost about .3 in the 1/4
Old Dec 22, 2002 | 11:08 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
GM has a 502 cui ram jet engine 500hp 500 torque and has 48 mm TB........................58 mm is def. going to be a overkill! Do a seach and you will find alot of info.........
/N.
Old Dec 22, 2002 | 01:07 PM
4L60bliss's Avatar
This is a heated topic just like Speed Density -vs- MAF that some people will die for
It seems though, that the general concensus is, that unless you are running a stout 383 or more, a 52mm is more then enough.
And if it makes a difference, I ran a 13.5@ 103 on stock runners and stock TB.
Old Dec 22, 2002 | 04:46 PM
Scania's Avatar
Car: 1989 Corvette
Engine: 350 Tpi
Thanks guys. Well i think im going to start whit a bigger fuel preasure regulator and these new runners.
Old Dec 22, 2002 | 05:11 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
That will all work much better, and cost close to the same. Also I would look into have a chip made up or get into makeing your own even.
Old Dec 23, 2002 | 01:17 AM
XxPichulonxX's Avatar
i went with the 52mm on my almost stock engine (the old one's shaft was loose giving me a high idle 1,500RPM) so I just got a performance part as a replacement and 58mm is definitly overkill, have a buddy who put that on ported plenum and all and the thing would bog like it lacked adequate fuel.
Old Dec 23, 2002 | 02:03 AM
bigals87z28's Avatar
Car: Check The Sig
i say, if ur gunna build up a engine, and keep the TPI set up... get the 52
Old Dec 23, 2002 | 08:17 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
GM ships the 500hp Ram Jet 502 with a 48mm throttlebody. Food for thought.
Old Dec 23, 2002 | 08:33 AM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I'm not trying to argue, so don't take this the wrong way, but what your saying is overkill. Like mentioned the 502 crate engines only come with a 48mm TB. Unless he is trying to build a engine with over 600 hp right now he would be wasting not only his money, but his fuel economy too. It isn't going to help him any right now, if anything it will slow the car down some. Just my 2 cents, but it worth it.
Linson
Oct 24, 2025 02:00 PM
Fred SS
Oct 12, 2015 11:27 AM
IROCNParts
Sep 24, 2015 10:50 AM
Magman
Sep 14, 2015 01:30 AM
Thornburg
Aug 27, 2015 08:33 PM
