front main seal
Old Dec 28, 2002 | 12:04 PM
demon138's Avatar
Car: 89 Pontiac GTA Trans Am
Engine: T.P.I. 383 Stroker
Transmission: Monster 700R4
front main seal
can i just loosen the oil pan and timing cover and slip the new seal in? or would i have to take off the whole oil pan ?
Old Dec 28, 2002 | 12:28 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
preferably drop at least front of pan- which requires removal of basically all the screws- which i think is easier than removeing timing cover cuz you gotta pull off the dampner and then reinstall it
good luck
Old Dec 28, 2002 | 01:05 PM
4L60bliss's Avatar
What seal are you trying to replace? If you are talking about the front crank seal, then you must remove the dampener. The seal is removed and tapped back in from the front of the timing chain cover, so no need to loosen the cover or oil pan.
If your talking about the front of the oil pan, then you need to remove the whole oil pan, since that front seal is really part of a one piece oil pan gasket.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
xxx3man`
Sep 23, 2015 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Exxon Limited
Aug 9, 2015 08:13 PM
