Has any one heard of a 1990 rs that had a 350 put in at the dealership?
Old Jan 10, 2003 | 05:07 PM
johnboy's Avatar
Has any one heard of a 1990 rs that had a 350 put in at the dealership? I found some one that is selling one and I wanted to know if it would be any good.
Old Jan 10, 2003 | 05:53 PM
ssbowtie1's Avatar
Only if it was a B4C police package its in RS trim so it has the stock hood and no wing.
Old Jan 11, 2003 | 08:08 PM
bigals87z28's Avatar
Car: Check The Sig
to check for the b4c, look under the center console pad for the RPO list... if u cant gain access to inside, the B4C has dual piston calipers in the front... thats what will be most distinguishable out of all the exterior accessories
Old Jan 12, 2003 | 05:52 AM
johnboy's Avatar
i fouind out its a 350 tbi
Old Jan 12, 2003 | 07:52 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
nope it isnt factory. make sure its a 350 and not a 305. Ive seen ppl try to pawn that off too.
Old Jan 12, 2003 | 08:47 AM
vwdave's Avatar
Someone told me the 305's had a castng on the driver's side that says "305" on it.
You cannot make a 350 out of a 305, so dont let him tell you that.
Old Jan 12, 2003 | 10:08 AM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
on the driver's side rear of the block just under the head it will say GM 5.0L or 5.7L. but i don't know of any "dealerships" taking the 305 out and putting 350 in their place.
Old Jan 12, 2003 | 10:17 AM
Scott C's Avatar
Check the emssions sticker under the hood at the front. That should at least tell you what the car was supposed to have in it...I'm betting that the "dealer" doesn't know anything about the car except that he hopes you buy it
Old Jan 12, 2003 | 03:22 PM
johnboy's Avatar
ok i looked on the emssions sticker and it does say 5.7L
i am going to post a pic in a few min
Old Jan 12, 2003 | 03:37 PM
johnboy's Avatar
ok its to dark to get a good pic of it (live in maine). but i will do it tomorrow. but it does say 5.7.
Old Jan 12, 2003 | 07:37 PM
mrr23's Avatar
Engine: 360 HSR
then it should also be a TPI motor. a B4C option for police.
Old Jan 12, 2003 | 08:37 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
wow...
Too bad the B4C option didnt come till 91.. So that must be a really really really rare RS then huh?
Kat
Old Jan 12, 2003 | 09:33 PM
johnboy's Avatar
its not the B4C only has a 110 speedometer. it is a tbi. i did buy buy it the person i got it from said they had only found 3 other ones like it on the net.
Old Jan 12, 2003 | 10:27 PM
iroc22's Avatar
Well it wouldn't be a B4C anyway since it says in the original post that it was a dealership installed 350; not a factory installed 350. Dealerships used to do engine swaps all the time. It isn't common at all anymore though because of EPA and new emissions laws.
Old Jan 13, 2003 | 07:26 AM
johnboy's Avatar
i put the image in "Reader's Rides"
Old Jan 13, 2003 | 07:51 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
It's not going to have a 5.7 hood sticker if it is a dealership installed engine. If it was a 5.0 replaced with a 5.7 by the dealer it would still say 5.0 under the hood.
Old Jan 13, 2003 | 10:12 AM
Jza's Avatar
Jza
Old Jan 13, 2003 | 10:13 AM
Jza's Avatar
Jza
Hmm. It's a TBI?
Old Jan 13, 2003 | 10:30 AM
Scott C's Avatar
Very interesting...the sticker shows a base timing of 6*, which is a 350 TPI setting, not TBI. 305 TBI base timing is 0*, correct?
Old Jan 13, 2003 | 12:39 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Ok I'll play.. Whats the VIN # of the car?
Kat
Old Jan 13, 2003 | 12:49 PM
iroc22's Avatar
Yup.
Old Jan 13, 2003 | 03:21 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
so some idiot put a new sticker on the cowl. What's the 8th digit of the VIN?
Since you're probably not dealing with a stock motor, the only way to be sure is to pull a head, or get the casting number off the block.
Old Jan 13, 2003 | 07:14 PM
johnboy's Avatar
Ok I called gm Customer Assistance Center I gave them the vin and they said it did come with a 305 from the factory. But she said that it did have a 350 put in at the dealership.
Old Jan 13, 2003 | 07:21 PM
mrr23's Avatar
Engine: 360 HSR
good deal then.
Old Jan 13, 2003 | 07:28 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
It's built for Canada too. They could probably get away with it.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
camaro71633
Sep 1, 2015 10:24 AM
sreZ28
Aug 14, 2015 07:48 PM
Sanjay
Aug 12, 2015 03:41 PM
