Post pix of your Cold Air Ram-Pod setups
Old Mar 31, 2003 | 10:26 PM
  #51
BOTTLEDZ28's Avatar
Transmission: A4
JM, nice job. wanna make me one but run it on both sides?
Old Mar 31, 2003 | 10:35 PM
  #52
bigals87z28's Avatar
Car: Check The Sig
i wana make one of thoes so bad, but i would need to relocate the bat. to the trunk. i really dont wana go to that right now.... looks like im just gunna break out the dremmel and start cutting out the air boxes... oh well.. thoes look really good guys..
Old Apr 1, 2003 | 12:11 AM
  #53
aziroc's Avatar
Car: 86 IROC-Z
Engine: 406
that set up (the 1 with that K&N right up on the TB) is the stupidist thing someone can do.. there is a guy that goes to my mechanics shop that has it this way.. he wont change it cause "it looks cool" to bad hes sucking is SO much hot air.
Old Apr 1, 2003 | 12:34 AM
  #54
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I don't see why people even bother with the ducting. Just cutting it all out and putting the filter in lets in more air and I don't see how there could be any disadvantage. Especially if you don't drive it in all weather.
Old Apr 1, 2003 | 01:23 AM
  #55
guest's Avatar
if you want to see HITHERE pretty well done cold air mod go to
http://iroczdave.sytes.net/IROCZDAVE...TEM%20PAGE.htm
HITHERE did it to my 1987 iroc-z tpi......HITHERE also just bought ahypertech air charger part # 4000.... to put on the throttle body....also HITHERE TORNADO.....helps out HITHERE little as well.....my throttle responce has improved HITHERE good bit RPMs climb HITHERE bit faster....my air delivery almost complete....good luck
Old Apr 1, 2003 | 05:35 AM
  #56
Administrator
You really put that thing in your intake??
Old Apr 1, 2003 | 10:16 AM
  #57
Car: Check The Sig
i dont see anything on that link... can someone post pics or put up a new link... thanks
Old Apr 2, 2003 | 12:03 PM
  #58
guest's Avatar
here are some pics
Attached Thumbnails Post pix of your Cold Air Ram-Pod setups-ram-20air-20diagram.jpg
Old Apr 2, 2003 | 12:05 PM
  #59
guest's Avatar
Here's basically what I did...........
Old Apr 2, 2003 | 12:07 PM
  #60
guest's Avatar
there are a lot of them
Old Apr 2, 2003 | 12:08 PM
  #61
guest's Avatar
under the air box
Old Apr 2, 2003 | 12:10 PM
  #62
guest's Avatar
close up of under
Old Apr 2, 2003 | 12:13 PM
  #63
guest's Avatar
As you can see in the above photos the 87- up IROC's/Z28's ( I believe with electric fans) came with these plastic panels to help divert incoming air from the grill into the radiator......
Old Apr 2, 2003 | 12:14 PM
  #64
guest's Avatar
When you set the modified air filter box in place you can see where the connecting tubes have to go
Old Apr 2, 2003 | 12:16 PM
  #65
guest's Avatar
These pics show the modified air filter box with the lower part cut off, and the connecting tube prototype templates......This photo shows just where the Ram Air intake holes need to be cut......
Old Apr 2, 2003 | 12:17 PM
  #66
guest's Avatar
Here you can see the holes that have been cut, I used a Dremel tool to do this and I had to use silicone glue to join the two parts together.....
Old Apr 2, 2003 | 12:20 PM
  #67
guest's Avatar
Here's most of the template I made with some plastic......
Old Apr 2, 2003 | 12:23 PM
  #68
guest's Avatar
here is apic of the unfinished box folded
Old Apr 2, 2003 | 12:25 PM
  #69
guest's Avatar
This last pic shows one of the boxes completed...use duck tape
to hold around curve....
Old Apr 2, 2003 | 12:26 PM
  #70
guest's Avatar
This shows one of the finished connector boxes in place......
Old Apr 2, 2003 | 12:27 PM
  #71
guest's Avatar
Now both boxes are in place and ready to put everything back together!
Old Apr 2, 2003 | 12:29 PM
  #72
guest's Avatar
The first time I got out on the road I immeadiatly felt a HUGE difference in throttle responce on both the low and middle end of the power band, sorry I don't have any dyno sheets to show the actual results...... just take your time and it will run and look great it took me 3 days to finish.... and it was worth every bit of time i put in it..... good luck
Old Apr 2, 2003 | 12:39 PM
  #73
guest's Avatar
are you talkin about the tonado? yes i figured i could give it a shot.... and beleve it or not i was satisfied(SP) with the air box in and the air charger in it helped..... here is a pic of the air charger
Attached Thumbnails Post pix of your Cold Air Ram-Pod setups-aircharger_engine.jpg
Old Apr 2, 2003 | 12:42 PM
  #74
guest's Avatar
you can pick a air charger up at any autozone for about 45-50 bucks
Old Apr 2, 2003 | 06:26 PM
  #75
90FormulaWS6's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Transmission: WCT5
but the "air charger"/air foil from slp for less than $40
Terrell351
Jun 13, 2021 01:13 PM
kyle5647
Aug 15, 2015 11:56 PM
drathaar907
Aug 6, 2015 04:20 PM
