bone stock 350 tpi
Old Jan 29, 2003 | 08:36 PM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
bone stock 350 tpi
what are some good mod's to start out with on a bone stock 350 tuned port
Old Jan 29, 2003 | 09:04 PM
NiceTry's Avatar
Headers and exhaust. Then, a convertor and some suspension work.
Old Jan 29, 2003 | 09:17 PM
Car: 89 Camaro RS
Engine: 355 TBI
i dont have to take emmisson test so i dont need a converter
Old Jan 29, 2003 | 09:39 PM
E.T.'s Avatar
I believe he is talking about a TORQE CONVERTOR.
Old Jan 29, 2003 | 09:49 PM
FlamedROC's Avatar
Car: 1989 IROC-Z
Air foil
porting the plenum
smooth runner ports
headers
Under drive pullys
removal of smog pump
high flow cat
Just some cheap fast goodies to start with B4 getting into the big expensive stuff like cams, heads, and power adders ( superchargers, Turbos & Nitrous)
Old Jan 30, 2003 | 08:32 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
Hey camaro89rs355,
Emphatically -- FORGET the other mods get a 3.42 POSI in as soon as you can what on earth can you do with a 355 and a 2.73 OPEN diff ? Talk about not putting the power to the pavement.
After that ? Cold air, tune the engine -- make sure you are getting stock or better than stock numbers out of the setup. Why spend cash on bolt-ons when your coil is putting out 1200 volts at WOT or your O2 sensor is reading low ? Etc, etc.
Exhaust is easy power and sounds great as well.
my .02 cents worth,
RP.
Old Jan 30, 2003 | 11:20 PM
Car: 89 Camaro RS
Engine: 355 TBI
Originally posted by palric
Hey camaro89rs355,
my .02 cents worth,
RP.
the 355 and 2:73 are in my 89 rs. and i got some 3:42 i just dont have them in yet. This 88 iroc is for my friend's car
jaridjohn
Jul 8, 2024 03:49 PM
camaro71633
Sep 1, 2015 10:24 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
