Does anyone make a Tall centerbolt valve cover for stock TPI heads?
Old Jan 31, 2003 | 08:52 AM
NiceTry's Avatar
Just like the subject says.
Old Jan 31, 2003 | 08:54 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
yeah. I don't have names or web addresses, but there's a few. Try Ebay for ideas.
Old Jan 31, 2003 | 10:36 AM
bnoon's Avatar
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
Heheheheheheh, just reading the new Summit flier valve cover section right now!!!
I don't know the exact demensions yet, but Summit makes a set of fabricated aluminum center bolt valve covers PN SUM-440336 listed at $194.39 a set. From what their tech says, they offer increased clearances for most valvetrain combinations. As with most fabricated sets, they may not have emission hook ups (you'd have to add those yourself).
Edlbrock also makes a set, but again, you'd have to ask the Summit tech for dimensions. Part numbers EDL-4246 or EDL-4247 depending on what year you have and which side your breather hole is on.
Old Jan 31, 2003 | 11:31 AM
BOTTLEDZ28's Avatar
Transmission: A4
$200 for valve covers.. NOT! how about spacers. There has to be good decent pairof valve cover spacers out there. then you just need longer bolts
Old Jan 31, 2003 | 11:32 AM
87transam5.7tpi's Avatar
Speedway motors used to make them. I went to there site but couldn't find them anymore, I hope I didn't miss my chance to order em
Old Jan 31, 2003 | 07:35 PM
gsf-87IROC's Avatar
Car: 87 IROC-Z
Engine: 383 HSR $8D
I have seen die cast aluminum tall valve covers for centerbolt heads. They were like 90 bucks at a swap meet...but you can get the same thing online for around 120 or so.
Be careful because tall valve covers look like they will hit the stud on the back of your alternator if you have the full serpentine setup.
FWIW: I have factory steel covers and other than looks...they fit with my Comp Pro Mag roller rockers just fine...not sure if that is why you are looking or not...but just my .02.
Old Jan 31, 2003 | 08:03 PM
87IROC350's Avatar
Engine: 5.7
https://www.thirdgen.org/techbb2/sho...hreadid=157589
Old Jan 31, 2003 | 08:41 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I picked up a set of tall polished aluminum off e-bay for $54. They are on there quite frequently.
Attached Thumbnails Does anyone make a Tall centerbolt valve cover for stock TPI heads?-valve.jpg
Old Jan 31, 2003 | 09:16 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
Did you install them yet? If you have the serpentine setup was the alternator in the way?
Old Feb 1, 2003 | 08:14 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
There should be no interference with the altenator, the positive bolt on the back of the altenator will be close, however, there is room it trim the bolt a bit shorter if necessay. That little black plastic cap over the bolt, if you still have it, will have to be removed, but otherwise, no problem.
On the passenger side the air diverter box will have to be shimmied a bit to get it to have a touch of clearance above the valve cover.
camaro71633
Sep 1, 2015 10:24 AM
NBrehm
Aug 25, 2015 11:49 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
marcusaw
Aug 10, 2015 08:13 AM
mustangman65_79
Aug 8, 2015 01:18 AM
