lt1 camshaft question
Old Feb 3, 2003 | 09:41 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
hey, would i get similar numbers and power from a lt1 camshaft with 1.6:1 rockers as a lt4 with 1.5:1? is there much difference?
anyone have the specs for an lt1 cam? thanks for the help
Old Feb 4, 2003 | 03:54 PM
Swapmaster's Avatar
The two cams are about the same. Nothing to get excited about.
Old Feb 4, 2003 | 04:05 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
well i was gonna get a lt4 cam down the road but i found a lt1 cam for 20 bucks so...
Old Feb 6, 2003 | 12:49 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
LT1 cam .447"/.459"
lift after 1.6 rockers .715"/.734"
LT4 cam .476"/.480"
lift sfter 1.5 rockers .714"/.720"
there you go.
i plan on getting a LT1 cam in my 89 305tpi and then getting roller tipped 1.5's
Old Feb 6, 2003 | 03:45 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
thanks for the info man
Old Feb 6, 2003 | 03:49 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
Originally posted by wyclefsirocz
LT1 cam .447"/.459"
LT4 cam .476"/.480"
there you go.
Think those second numbers are little out of whack.
Take 1.6/1.5 * the lift with 1.5 rockers to get lift with 1.6 as opposed to 1.5.
I believe the first set of number for each is the lift with 1.5 so with 1.6 you get 0.477 and 0.490 then 0.508 and 0.512.
Old Feb 6, 2003 | 05:18 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
yeah ur right, those figures would be with the 1.5's already...just realized that too
Old Feb 7, 2003 | 01:50 AM
Engine: peanut LB9
Fevre is right, i messed up the #'s
it was like 2:45 in the morning
sorry about that just tryin to help
Old Feb 7, 2003 | 03:15 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
I read that and I was like... wtf? That would take valve float to a whole new level - lol.
Old Feb 7, 2003 | 01:34 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
its cool, mistakes are made, i appreciate the info...what kind of rockers r u getting, are they self aligning or are u puttin in the guideplates, etc?
Old Feb 7, 2003 | 05:18 PM
Engine: peanut LB9
i'm right now stuck in between cams...
the LT1 cam and the
Ram Jet cam
Duration @ 0.050 (I/E): 196/206
Lift, (I/E): .431"/.451"
Lobe Separation: 109
RPM Range: 800-4500
Type: Hydraulic Roller
this is because i have mostly stock 305tpi.and this cam is a great improvement over my stock cam.
if get the ram jet cam, i'm gonna put on stamped 1.6's this will only cost me 250 to do nd will give 15hp.
but if i get the LT1 cam i'm looking at the range of 500, to do with new springs and new 1.5 roller tiped rockers
Old Feb 8, 2003 | 08:23 PM
IROCZ88x's Avatar
Car: 1988 IROC-Z
Engine: LB9
again, where are u gonna get these rockers? ...why not the lt4?
Old Feb 9, 2003 | 09:50 AM
Engine: peanut LB9
i'm not gonna get the LT4 cam, cause i don't want something that radical for my 305right now. i drive this car to school, twice a day and to work twice a day, so i still need to have a good daily driver, plus i don't have headers yet..
from www.SDPC2000.com
they are comp cam magnum rocker arms for 87+ sbc's
and they are 1.52 not 1.5 ratio
87iroctheo
Dec 4, 2016 11:47 AM
blackroc68
Sep 1, 2015 08:01 PM
midge54
Aug 29, 2015 09:51 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
redmaroz
Aug 16, 2015 11:40 PM
