Cam recomondations?lt1 intake afr heads--->
Old Feb 7, 2003 | 10:13 PM
383LT1intake's Avatar
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
i jus swapped to speed density so i thought it would be good time to swap cams what would you guys think would be a good one for me? heres my set up
LT1 intake
afr 195cc heads
10.5- compression
383 stroker
hooker 1 3/4" super comps
mufflex 4"
373 gears
1.65 roller rockers
700r4
2600 vigulante stall
i currently have a compucam 2032 214-220 and my best times been 12.4@110
Old Feb 7, 2003 | 11:43 PM
BuckeyeROC's Avatar
Car: 2015 Camaro Z/28 & 2013 Super Bee
Engine: LS7 and 392 HEMI
Depends on how radical you want to go or high to rev.
Check out the LT4 HOT cam and Comp Cams 306. You'll want a higher stall w/ the CC306, maybe the HOT cam too.
Old Feb 8, 2003 | 09:20 AM
86 IROC's Avatar
I have a similar set up, you will like the CC306 with that motor, it's part #08-306-8. TPIS' ZZX cam is also a great cam for that combination.
Old Feb 8, 2003 | 10:07 AM
Car: 92 camaro
Engine: 383 stroker
is the driveabilty good with the cc306 cam? this is my daily driver jus dont want any headaches is that from tpis?
Old Feb 8, 2003 | 11:37 AM
86 IROC's Avatar
The CC306 is from Comp Cams, ZZX is a TPIS camshaft. The CC306 is a bit choppy, I'll admit that. You might want to drop back one cam to a CC305 if you want a daily driver camshaft. Lumpy cams and loose converters don't bother me much, but I will admit that the CC305 will have better street manners vs. the CC306 or ZZX.
Old Feb 8, 2003 | 11:45 AM
Car: 92 camaro
Engine: 383 stroker
hey thanks 86 iroc choppy doesnt bother me as long as its still has good driveability do u by chance know the specs on cc305 and cc306 off the top of your head whats the center line and hows thank 7730 like the choppy idle do u burn your own chips? you have any times with either cam im running 12.4@110 now id hate to pick wrong cam and slow down thanks
Old Feb 8, 2003 | 11:57 AM
86 IROC's Avatar
My cam which is the non-LT1 version of the CC306 is: 230/244 duration @ .050" lift, 112 LSA, 108 intake centerline, .510/.540 lift with 1.5 ratio rocker arms. The CC305 is: 224/230 duration @ .050" lift, 114 LSA, 110 intake centerline, .510/.510 lift with 1.5 ratio rockers.
I don't do my own chips, I don't have the equipment or enough of the know how as of yet. I'm working with a friend from the board on that. I am going to try and get it tuned the best I can using a wideband 02 sensor for now. Datamaster software is supposedly better for what I'm trying to do - but I just don't have the cash to invest in that right now.
Old Feb 8, 2003 | 12:44 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I say cc306 and a 3600 vig Get ready to tune... that SD isn't gonna like that cam
Old Feb 8, 2003 | 05:20 PM
Car: 92 camaro
Engine: 383 stroker
im getting an ed wright chip for now but i plan to start doing my own burning shortly you think itll run ok with his chip where i can drive it are those the part#'s for the cams? who sells em cheapest and what do they run? you know anyone else on here running that type of lumpy cam with 7730 thanks guys i wish the searched work later
Old Feb 8, 2003 | 05:40 PM
86 IROC's Avatar
# 08-306-8 for the L98 version of the CC306 to fit the earlier roller non-LT1 engines, # 08-305-8 for the CC305 cam.
This guy is running the TPIS ZZX cam in an AFR headed 383 ->11SEC91Z He is running the stock SD harness & ECM in that car, uses a chip from TPIS. The ZZX cam is 239 duration @ .050" & .558" lift, 112 LSA - very similar to the CC306.
Old Feb 8, 2003 | 11:48 PM
'87FAKE-IROC-Z's Avatar
Car: Damn
Engine: This
Transmission: New Stuff
The hot cam would probobly be a little small for a 383 with an LT1 intake, another vote for the cc306 and stall.
Old Feb 8, 2003 | 11:51 PM
Car: 92 camaro
Engine: 383 stroker
you think the 306 would pull enough vacum for my sd 7730 ecm thanks
Old Feb 9, 2003 | 12:54 AM
86 IROC's Avatar
It's a bit choppy, but my brakes still work. I have a little in-line valve that interrupts the hose going from my brake booster and the intake manifold. Many LT1 guys have been successfully running the CC306 cam. The CC305 is one camshaft down and is a great cam as well. I would go with the CC305 if you want to keep this car as your daily driver, and might have to sit in traffic for any length of time. No matter what, you will make more power that your current camshaft with either cam.
Old Feb 9, 2003 | 07:06 AM
STOCKROC's Avatar
I ran the cc306, and did not like it. I switched to it from a very small slp cam (the specs were somthing like 207-212 .480-.487 on a 112. I went slower with the cc306. Ran a best of 12.5 @ 114 with the smaller cam, then after the switch I only went 12.8@112. I even switched gear to match the bigger cam (changed from 3.73 to 4.30. 60 ft times were similar with both setups in the 1.9 to 2.0 range. I even ran the times for the cc306 in much cooler air. However my car had a tpis chip for the smaller cam, and I never got it retuned for the cc306. I believe the cc306 didnot work well because of the huge split in duration between intake and exaust. Imo afr heads respond better to a cam closer to a single patteren due to the extremely good ratio of intake to exaust flow. I also experienced power brake lose after about 3 good pumps of the brake pedal. You porbably wont run into this problem on a 383. My mods were stock 350 shortblock, miniram, afr 190's,hooker supercomps, and all the other boltons. On a different short block (all stock pieces, except it was balanced) I went 12.1 @118 with a tpis zz409 ( this was done on the same tune from tpis for the small slp cam). Ive been through several engines and cam swaps. I am about to switch engins yet again. I lost my stock short block due to the screw that holds the airfoil in place getting sucked in (lost a piston and rod). My next engine will be a fully forged 383 with all the same mods except I will be installing a tpis zzx cam.
If you realy want a cc306 I am going to sell mine.
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
