LT1 or LS1 heads on ex-tpi...
Old Feb 9, 2003 | 07:26 PM
Ivan383's Avatar
Hey guys, I have the opportunity to purchase either LT1 or LS1 used heads, the engine they would go onto is an 1988 corvette 383 ex- TPI with factory aluminum heads, I have purchased a converted LT1 intake from John Millican. Will either set of heads work on my 383 set-up? If not I will keep the factory heads and port/polish.Thanks!
Old Feb 9, 2003 | 07:41 PM
Z_Ghost's Avatar
ls1 heads will not work.
Old Feb 9, 2003 | 07:51 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Ivan,
I will also add you cannot even think about using the LS1 heads on an early SBC.
Now, you CAN use the LT1 heads on an early SBC like yours but you will have to do some machining. They are not a direct bolt on but many people have done it.
If you do go the LT1 heads/LT1 intake route you need to let me know for sure. I don't re-drill the intake bolt pattern if people use LT1 heads with LT1 intake. It would also be cheaper since I don't have to drill the bolt pattern.
Here's instructions on converting LT1 heads for use on a SBC.
Part 1:
Old Feb 9, 2003 | 07:52 PM
Engine: 4.0L
Part 2:
Old Feb 9, 2003 | 10:29 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Do you have any bigger scans of this? It's quite hard to read.
Old Feb 10, 2003 | 07:41 AM
bigals87z28's Avatar
Car: Check The Sig
GET BETTER GLASSES! hhehehehe im kidding... yea it is kinda hard to read... anyone come across some power numbers on swapping these heads? is it really worth the time and money?
EDIT: i see the numbers.. 35 more hp then ZZ3 alum heads? are thoes like the L98 Alum. Vette heads?
Old Feb 10, 2003 | 12:03 PM
90iroc5spd's Avatar
Car: 87 aniv vert, 90 Iroc, 87 LT
Engine: LB9, LB9, carbed 305
Transmission: MM5, MM5 conversion, MM5 conversion
Axle/Gears: 3.45, 3.73, 3.73
anyone know of a website that describes this better?
and the zz4 heads are copies of l98 heads, i dunno about the zz3's
Old Feb 10, 2003 | 12:07 PM
Guest
Guest
Posts: n/a
Reasons i can think of for swapping:
Use LT1 intake.
Ran out of thoughts.
There was quite a bit of this going around years ago, with Fords... using a Cleveland head on a SBF like a 302 or 351W. Its pretty much died, mainly because there was non-standard machine work involved, and the heads available that were bolt ons worked so well anyway. Almost a novelty, if you will. I'd imagine this sort of swap will go the same direction.
Old Feb 10, 2003 | 09:33 PM
Engine: 4.0L
I can e-mail it to you. My site is down that has the bigger scans on it. 3GO has an attachment limit so I cannot upload the larger scans.
millicanga@comcast.net
Old Feb 13, 2003 | 04:45 AM
Engine: 4.0L
Here's a link to a little bit bigger scans
http://www.lt1intake.com/LT1_retrofit.htm
midge54
Dec 27, 2019 04:14 PM
deracer
Apr 11, 2016 12:04 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
sreZ28
Aug 14, 2015 07:48 PM
