TPI My Car Is Bogging and smoking
Old Feb 18, 2003 | 04:31 PM
SmokinL98's Avatar
My Car Is Blowing White Smoke.....And Sounds Like Someone put a cam in with out me knowing..........Its boggs like crazy and sounds like sh*t.......And reaks like it is running very rich......stinks of gasoline??????? If anyone out there could answer these problems I would Appreciate it??? My Poor 91-Z Has Cought A Cold....
Old Feb 18, 2003 | 08:05 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
You might have a blow head gasket, check your coolet and see if it's all gone or low. And also your oil, see if it's milkly. I hope I'm wrong though, cause that's a big pain to fix.
Old Feb 18, 2003 | 08:49 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Yeah sounds like a blown head gasket man
Old Feb 18, 2003 | 10:34 PM
383 rocket bird's Avatar
What kind of shape is your ignition in? have you checked for a strong spark?
Old Feb 18, 2003 | 10:55 PM
camzcruizer's Avatar
clogged catS?
Old Feb 19, 2003 | 12:54 AM
SmokinL98's Avatar
I checked Oil and Coolant, Nothing at all, I dont understand it......I Think its a fuel delivery problem
Old Feb 19, 2003 | 03:52 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
well keep a eye on it, when I blew a head gasket it was doing the same thing that you have wrote. Sounded like a cam(miss), white smoke, and fuel smell. My oil didn't get milky until a few days later, after draining the oil pan(looked like yahoo)also loss of power. It didn't smoke to bad, I didn't notice it till one day sitting at a light. It was smoking light, not like crazy just alittle bit, But I was getting low on coolet. But also check out, your plugs that might be why your car sounds like a cam, a miss will cause that.
Old Feb 19, 2003 | 03:55 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
one more thing if one of your plugs is fouled, that would also cause loss of power, and your car to bog down. Hopefully that's just your prob but it still sounds like a blown head gasket.
Old Feb 20, 2003 | 12:34 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I had something similair happen to me. The car would bog, smoke, and smell like gas under 1/4 throttle or more. Turned out my cats were plugged. I managed to figure it out by taking a hammer and hitting the cats acouple times. The car would act fine for about a mile or so, then it would plug back up again and bog again.
Old Feb 21, 2003 | 12:00 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
The white smoke could be an intake manifold leak too right? I had that problem but without the gas smell or the missing.
Old Feb 21, 2003 | 08:16 AM
ctandc's Avatar
Seems like the basics are missing here...
When's the last time you did a tune up on the car?
Have you checked the plugs? Spark plug wires? Cap? Rotor?
Once you've gone through those, what about the PCV valve? Any hoses cracked or messed up causing vacuum leaks?
If TPI, DEFINITELY check for a leaking / stuck open injector, it will cause ALOT of problems...
I'd do that before I started tearing the engine apart. If the oil does NOT have coolant in it, and the oil cap doesn't have white crud ( water condensation ) underneath, I'd look elsewhere....
If you think it might be a head gasket...are you losing coolant and can't find a leak?
If in doubt, run a pressure test on the cooling system. You can also get a test done to detect exhaust gas in the coolant....
HTH
1nastygta
Oct 28, 2015 08:51 PM
jharrison5
Aug 19, 2015 05:53 PM
drathaar907
Aug 10, 2015 07:44 AM
squiggy2
Aug 9, 2015 09:30 PM
killer777
Aug 8, 2015 02:47 PM
