another cam question
Old Feb 19, 2003 | 12:01 AM
jbonz28's Avatar
ok I know that there is a lot of these and I've read through some and learned some so I tink I've got an idea of what i want I'd just like some imput from you guys. Anyways I was looking in my old next generation book and here is exactly what the specs are: hyd flat tappet dur.050 212/212 lift .444/.444 lobe seperation 112 its in the computer compatible cams section and they say its 50-satate legal,stock 305tpi.
is this a good choice? I've got a 86 305 tpi flowmaster exhaust, k&n filters, home made ram air, de screened maf and thats about it everything else is stock. I have nothing big planed for the future maybe just do a tb bypass, exhaust cut out, air foil, high flow cat, and other minor things just for a little extra pop.
I dont want to change anything else when I do this cam I wanna stay with stock valve springs and what not thats why i think this may be a good choice for me and i do want to go a bit on the concervative side cause I want the car to last as is and this cam is a huge improvement over the penut cam that came in it from what the tech data says its dur.050 is only 174/198 i believe so it should be a good improvement, well thats it thanks for the help
Old Feb 20, 2003 | 06:25 PM
jbonz28's Avatar
jeeese
Old Feb 20, 2003 | 09:58 PM
mikobu3's Avatar
go with the comp xtreme energy 212-218 good for 45 hp over the peanut cam
Old Feb 21, 2003 | 04:36 PM
jbonz28's Avatar
and i can can keep everything the way it is without any worries? if so then hell yea
Old Feb 21, 2003 | 04:52 PM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
I'd go with either of those cams in your 305. They should make quite a difference, but yet not over cam the car.
Old Feb 21, 2003 | 08:27 PM
jbonz28's Avatar
thanks for the help it looks like thats what i'm gonna do i'll make a bet that it gets me in the 14's very high 14's but 14's none the less
Old Feb 23, 2003 | 08:30 PM
mikobu3's Avatar
i'm guessing that with that xtreme cam ,and a good exhaust system,,and if you want to go 305 crazy port those heads with bigger valves,, you will hit high 13's ,, on my 305 i will do the heads when i change the cam ,,, people who have done the heads say they made 15% power , now add 15% with 190 hp is 220 hp then with the cam add another 45 hp and now you got a 265 hp . add some headers, with a vagilante tourqe converter and decent gears and you will see a very quick 305 .
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
