Porting & Polishing 305 heads, few questions.
Old Feb 20, 2003 | 12:06 PM
5SIZ's Avatar
Car: 1987 IROC-Z
I got a spare set of 305 heads that I am fully porting & polishing, I had a few questions on how I would approach polishing them.
Since the fuel mixes w/ the air @ the base of the intake before they enter the head on our tpi setups, would it be wise to fully polish the intake part of the head, I mean would it hurt atomization? or does it even matter at that point.
Also I will be using a TPIS intake, so would I have to burn a prom for the head/intake combo? I don't have acess to any prom burning stuff at the moment so would my car run witht he stock prom? I mean it's not like I'm changing the cam or something.
Thanks.
Old Feb 20, 2003 | 12:17 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Do not polish the intake ports. It needs that "rough" texture so the fuel and air will mix properly.
Old Feb 20, 2003 | 12:18 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Ok, what is polishable on the head then??
I thought it was pointless to polish the exaust part of the head.
Old Feb 20, 2003 | 12:23 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
very benificial to polish the exhaust size... will reflect heat and reduce carbon build up in the port.
No harm to polish the intake side either, especially with port injection.
http://www.cardomain.com/member_page...217306&page=22
Old Feb 20, 2003 | 12:27 PM
5SIZ's Avatar
Car: 1987 IROC-Z
Now that looks more like it
thanks.
Old Feb 21, 2003 | 01:33 AM
5SIZ's Avatar
Car: 1987 IROC-Z
anyways, what about the prom stuff, will I have to get a custom one or not.
Old Feb 23, 2003 | 05:08 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
polishing exhaust ports will help dissapate heat and reduce carbon buildin like mentioned..also the combustion chambers can be polished for the same reason, more beneficail to iron heads then aluminum because they dont dissappate heat as quickly as aluminum...
polishing the intake ports is a bad idea...the fuel will come out of suspension and will puddle in the chambers, NOT GOOD lol...
not only will this hurt performance and gas milege it will dig into your poscket further...having to have them ported and then them performing worse then before...(edit) if the puddling is bad enough then fuel can leak down the cylinder walls past the rings and into the oil..in which case a polished intake port and puddling fuel will be the last thing u worry about (edit)
it can be argued that with enough velocity through the ports that the fuel is moving fast enough that it doesnt run down the port walls.....yea maybe for a 1000 horse big block lol, but for your everday 400 horser you will be sorry for polishing the intake ports
as far and the intake base id say that if u have an had an AFPR then bump up the psi a little...it wont make a difference untill WOT but neither will the base really
HTH
Old Feb 23, 2003 | 06:04 PM
5SIZ's Avatar
Car: 1987 IROC-Z
thanks for the tip, I do have an AFPR and it is currently @ 49 psi WOT.
Old Feb 23, 2003 | 06:27 PM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
u should be good to go then...i read in a mag that at 52 psi an l98 performed best...so for your lb9 id say 49-50 will be great
my situation was oppisite...i had the fuel pressure i wanted i just couldnt get enough air into to lean it out...it was way rich
now i have a blown motor lol so i guess thas the least of my concers....
good luck man!
Jake_92RS
Jan 28, 2020 10:37 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
69 Six Pack
Oct 5, 2015 07:51 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
