lets get this straight
Old Feb 20, 2003 | 12:44 PM
mikobu3's Avatar
when i put the new 1.94 valves 1.65 what will i need , what will be reusable , do i need to change the pistons, how much will this cost, and will this help in performance, will the car run right
thanks
1986 305 tpi lb9
Old Feb 20, 2003 | 08:33 PM
kevinc's Avatar
Car: 1982 Z28
Wow. Just don't know where to start...you planning to do the whole job yourself with nothing but this board as your reference material?
Old Feb 20, 2003 | 09:54 PM
mikobu3's Avatar
no , my mechanic is going to do it i just want to make sure i get all the facts straight ,, i no i have to put the bigger valves in what else am i suppose to do
Old Feb 20, 2003 | 10:21 PM
kevinc's Avatar
Car: 1982 Z28
Sounds like there are two things you need to do, given a mechanic is going to do it:
1.) Take it to the mechanic.
2.) Pay.
Old Feb 20, 2003 | 10:26 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
hahaha
Anyway, you'll need new valves. How much is he charging you? I didn't think 305 heads were all that ecpensive. Why not just buy a set of heads and make even more power.
Old Feb 20, 2003 | 10:51 PM
fun Pain's Avatar
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
that is what i vote for, new heads if your mechanic is doing it he has less chance of messing up you heads, and then you have to anyways
Old Feb 20, 2003 | 10:59 PM
iroc22's Avatar
I don't think just changing your valve size from 1.84 to 1.94 is really worth the money. Spend a little more money and at least get the heads cleaned up, port/polished and get the bigger valves installed.
Rousseau92maro
Feb 1, 2016 05:12 PM
1990FirebirdGTA
Sep 22, 2015 07:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
FED 387
Sep 16, 2015 12:18 PM
TexasMaro
Sep 15, 2015 06:50 PM
