ESC location
Old Feb 20, 2003 | 02:19 PM
Tachy's Avatar
ESC location
I have a code "43" and a spare ECS module to try. problem is im too dumb to find the one on the car.. where the hell is this thing?
91 t/a - tpi - 305
Old Feb 24, 2003 | 09:07 AM
91FirebirdFmla's Avatar
Car: Green 1991 Firebird Formula
The module should be next to the power brake booster, near all of the relays. At least, that's what it says in the books. Although, I'm getting the same error code and I can't find mine either. I have a 91 model too. Maybe it was placed somewhere else for those model years.
Old Feb 24, 2003 | 09:25 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
I am pretty sure your ESC is in your Eeprom chip. Your cars are on the SD setup, not the MAF. The MAF has the ESC by the booster, the SD has it in the prom itself. That is why you cannot find it.
By the way welcome to both of you. Try using the search option to widen your outcome. By using the search option you usually get your answers that much faster, instead of waiting for replies.
Old Feb 24, 2003 | 01:25 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Ok my bad.
Old Feb 24, 2003 | 01:28 PM
kevinc's Avatar
Car: 1982 Z28
On speed density 3rd gens, the ESC is on the MEMCAL (inside the ECM, under the blue plastic hood, next to the PROM).
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Guys It is in the Memcal. Period! Don't go looking all over the engine compartment to find it. The ESC isn't there. It is in the computer. 90 - 92 cars had it on the memcal. 89 and under had it by the Brake booster.
Old Feb 24, 2003 | 07:05 PM
Is it common for the ESC module itself to need replacing or is it probably some component connected with the ESC? (I already replaced the knock sensor)
Old Feb 26, 2003 | 03:12 PM
BOTTLEDZ28's Avatar
Transmission: A4
is there a difference betweenthe 305 and 350 ESC on a 91z28. I put a 350 in and changed the chip but not the ESC.
Old Feb 26, 2003 | 03:46 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
I'm not really sure about the ESC difference when it is in the Memcal. I do know that thye are different when it come sto the 89 and under ESC one for the 305 and a different one for the 350 som most likely they are different in the 90 -92 also. So I will guess that yes, the 305 and the 350 use different Memcals.
Old Feb 28, 2003 | 07:30 PM
Tachy's Avatar
thanks for the welcome and the information.
Old Apr 8, 2003 | 08:04 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
what the hell is memcal???
Dan
Old Apr 8, 2003 | 08:06 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
The chip in the ECM
Old Apr 8, 2003 | 08:08 PM
are you talking about the PROM???
Dan
Old Apr 8, 2003 | 08:16 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Transmission: TH350
Yes!
bigjay89gta
Oct 15, 2015 08:04 AM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
meeklay812
Oct 1, 2015 03:46 PM
SRKLEGIN
Sep 30, 2015 07:19 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
