MAP, MAT, TPI, CTS, and their ground
Old Feb 22, 2003 | 08:20 PM
S10Wildside's Avatar
Does the ECM ground these sensors? I just finished my MAF to MAP swap and am checking power/grounds with the ECM unplugged. The wiring diagram doesn't show a ground there, but they should be grounded. Can someone confirm that the ECM grounds these sensors? and that they don't have thier own ground.
Old Feb 25, 2003 | 09:33 AM
Jza's Avatar
Jza
AFAIK the sensors are grounded through two sensor grounds in the ECM. So the ECM has to be plugged in or at least grounded in order for the sensors themselves to have a ground.
Old Feb 25, 2003 | 10:14 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: MAP, MAT, TPI, CTS, and their ground
If you're referring to the '7730 ECM, my
pinout ref page
http://www.eecis.udel.edu/~davis/z28/ECMs/86to92.txt
lists the grounds for TPS, CTS, MAT as pin B5
and MAP seperately as on pin B6
mike
jaridjohn
Jul 8, 2024 03:49 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
