Today was the big day!
Old Feb 22, 2003 | 09:32 PM
87GTA Runner's Avatar
Car: 87 GTA
After sitting since October in pieces, finally got the TPI put back together today. When I started it, it fired up, but shut off right away. After a couple more times it stayed running, but only by giving it gas. It would also break up while giving it gas. I have a new TPS and IAC, which I didn't adjust because I have no meter. I assume this is the problem, will an improperly adjusted TPS make it do this. I have 25# fuel pressure according to the gauge. I installed a Superram base, SLP runners, ported/siamesed plenum, CAI, airfoil, and TB bypass if this helps. I'm happy it even started, I thought for sure the timing would be messed up after removing dist. I hope it's just the TPS or IAC, don't feel like ripping everything down again. Thanks for any and all help.
Old Feb 22, 2003 | 09:56 PM
Car: 87 GTA
Forgot to say I put in new injectors also. These:http://cgi.ebay.com/ebaymotors/ws/eB...&category=6770
Old Feb 22, 2003 | 10:28 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Shouldn't your fuel pressure be around 40psi or so??
Maybe I'm wrong.. but that would be my guess
Old Feb 22, 2003 | 10:33 PM
Car: 87 GTA
I also put on an AFPR. So maybe I should bump up the pressure?
Old Feb 22, 2003 | 10:42 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
yup bump it to about 43
Old Feb 22, 2003 | 10:45 PM
Car: 87 GTA
After I raise the fuel pressure, I'll still have to set the TPS and IAC, right?
Old Feb 23, 2003 | 03:03 AM
rezinn's Avatar
Of course. The TPS reading is based off of the IAC setting, so you'll need to set the IAC first.
Old Feb 23, 2003 | 07:47 AM
Car: 87 GTA
One more thing. Should I set the pressure with the vacuum tube on or off the AFPR?
Old Feb 23, 2003 | 08:20 AM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Vacuum off.
Old Feb 23, 2003 | 11:34 AM
Car: 87 GTA
OK, here's the latest. I got the fuel pressure to 45#. The car still won't stay running without giving it gas. I can't adjust the IAC if it won't stay running. Should I set the TPS without setting the IAC? Maybe a vacuum leak? No fuel leaks anywhere. I thought I used up all of my @##$$% words putting everything back together. Now I'm finding more. It's going to be nice soon and I just want the car to run! Any ideas or thoughts. I'm open to anything. Does anyone have a drawing or schematic of the emission lines so I can be sure they are right? Thanks.
Old Feb 23, 2003 | 02:00 PM
IAC and TPS settings
Try that.
Are you sure you're setting the IAC correctly?
Old Feb 23, 2003 | 07:12 PM
Car: 87 GTA
That's the tech article I used to try to set the IAC, but the car won't stay running so I can't set the idle.
Old Feb 24, 2003 | 12:45 AM
Tmony69's Avatar
Car: 89 IROC x2
I would start checking for a vaccum leak somewhere
Old Feb 24, 2003 | 03:33 PM
Car: 87 GTA
I just got home from work and I'll go see if I can find a vacuum leak or something of the sort. If I find anything I'll let everyone know. If I don't find anything I'll let everyone know. I'll start by plugging lines on TB and work my way back to see if that helps at all.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Thornburg
Sep 1, 2015 03:39 AM
luvofjah
Aftermarket Vendor Review
Aug 31, 2015 11:22 AM
1Aauto
Sponsored Vendors
Aug 31, 2015 09:46 AM
spaigo
Aug 21, 2015 07:46 PM
