Stealth Ram install
Old May 16, 2015 | 11:06 AM
  #51
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Stealth Ram install
I do believe the sensor under the plenum is Intake Air Temp sensor.
If have seen folks just mill the connections for the coolant hoses right off the IAC plate....
Old May 19, 2015 | 01:38 PM
  #52
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Originally Posted by Rice01
Secondly, the "throttle body coolant cover" where the IAC is located... does anyone make a better looking IAC mount without the coolant fittings? word on the proverbial street is everyone does away with those anyway to keep hot coolant from warming the air stream through the throttle body...
Am I close on any of this or should I just go throw the dunce cap on for a bit?
TPiS sells a IAC housing without the coolant ports.
Old May 22, 2015 | 01:02 AM
  #53
Rice01's Avatar
Car: 1988 IROC-Z Camaro
Engine: 383ci SBC
Axle/Gears: 2.77 9 bolt borg warner
Awesome, Thank you. So I started throwing mine together and as I was moving the sensors and putting the new vacuum fittings and what not over to the new intake and plenum, The hole I assumed to be for the Cold start switch is quite a bit bigger than the Bosch 4318. I do have a plug that would fit, I just want to be sure my thought process is right on all this. Since the HSR does not use the Cold start injector, there is no purpose in the Cold Start Switch, so I am ok to not run one on the new intake?
Old Dec 12, 2016 | 02:51 PM
  #54
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
Subbed for future reference
Old Jul 22, 2019 | 11:15 PM
  #55
kenbob's Avatar
Car: 86 trans-am 1LE G92 WS.6
Engine: 305 LB9
Axle/Gears: 2.77 soon to have 3.45
Okay guys my oil pressure sensor is in the way of my new intake manifold hsr is the a newer sensor to use or just an adapter
Old Jul 23, 2019 | 06:44 PM
  #56
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
It's tight back there. I used a t shaped adapter, one hole fore the oil pressure sensor other hole for the gauge.
\brian
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
