TBI to TPI swappers please come in!
Old Mar 12, 2003 | 03:20 PM
Nasty_Bird_'90's Avatar
I just put an L98 into my L03 car. I'm having problems finding out where this plug goes. It's down near the ECM and branches off of the main harness. It's a 6-way connector with 2 pnk/blk and 1 brn/wht on the harness end and on the end that should be on the chassis harness has 2 pnk/blk, 1 grn, 1 blue and 1 brn wire.
I have both sides of the plug b/c it was cut out of a car but he cut it out so that it is still usable. Make sense? Let me know if you need clarification. This is all I need to get the car back on the road. I really need the help
One end of the plug is white ( the harness side) and the other is gray. Basically what I need to know is where do I plug the white part into on the L03 car?
Old Mar 13, 2003 | 01:03 AM
Bort62's Avatar
Pictures work nicely.
There is the Dash Harness connector, is that what you are describing ?
Old Mar 13, 2003 | 01:18 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I don't think that it is the IP harness. Theres another one under there that is a 6 pin connector IIRC.. Over the years they used it for a few differnt things. Like injector power and stuff like that.
Kat
Old Mar 13, 2003 | 01:24 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Better yet.. Does it look like this?
Kat
Old Mar 13, 2003 | 06:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI to TPI swappers please come in!
Nasty_Bird_'90, go to this site:
http://www.diy-efi.org/gmecm/ecm_info/1227730/
And at the bottom of that page are links to the wiring diagrams for your ECM. The '92 f-body, page 2, note the injector feeds. (IP stands for instrument panel).
This should get you going.
RBob.
Old Mar 13, 2003 | 08:23 AM
Kat
Yeah Kat, that's the one I'm talking about. I need it for the injector power. The pink/black wires. Any Idea that corresponding plug would look like on a '90?
Sorry about no pics, Bort, but I don't have a digital camera
Old Mar 13, 2003 | 10:54 AM
91banditt2's Avatar
Car: 1991 BandittII Firebird
Engine: 5.7 HSR
Axle/Gears: 3.27 9 bolt
what year did the L98 come out of?was it out of a speed denisty car(90-92)?
Old Mar 13, 2003 | 11:47 AM
Jza's Avatar
Jza
The injector power wires are on the gray 6 pin connector the branches near the clear IP connector. In later cars, the injector power wires were moved to the IP connector and the 6 pin connector was eliminated. (There's also a fuel pump power wire and coolant fan power wire on that connector IIRC?)
I'd bet the L98 in question is an '87 or '88. Am I right?
Old Mar 13, 2003 | 01:34 PM
Yep, you're right. It's an '86 L98 in a '90. So there are two injector wires, a coolant fan power wire and a fuel pump power wire? Which color wire is which? Thanx for the help!
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
evilstuie
Jan 9, 2020 08:29 PM
Dwayne614
Sep 28, 2015 08:33 AM
Sanjay
Aug 12, 2015 03:41 PM
