Trouble Codes
Old Mar 12, 2003 | 05:12 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
Trouble Codes
ok, i'm very pissed off at this shop called Oxnard Auto Clinic, so if any of you live in Ventura county do not goto this shop. I took my car in there to get a couple things fixed and now i have 4 trouble codes poping up!!!!!!!! Can any of you tell me whats causing these codes and how they can be fixed.
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
36. Burn off at mass air flow sensor OR
Problem in transmission shift OR
Fault in direct ignition system OR
Missing pulses in electronic spark timing signal
43. Low voltage at electronic spark timing circuit
Old Mar 12, 2003 | 05:13 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
One other thing
Also any ideas on why my car is trying to over heat ?
Old Mar 12, 2003 | 05:17 PM
91Z28-350's Avatar
what things were you trying to get fixed?
Have you checked the connectors for the EST and the MAP? The EST may be disconnected, for a timing adjustment and they forgot to reconnect it. The MAP, not sure what the hell they'd be doing there unless you needed to pull the plenum. Check the electrical connector, and the MAP vacuum tube.
overheating? bad...fans not turning on? coolant switch disconnected? It could also be a messed up ECU.
Old Mar 12, 2003 | 05:22 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
I did take the plenum out a while back, ported it, put in a new egr valve and a new fuel pressure regulator, but i connected everything back up.
they did have to put in a new distributor, new oil pressure sensor i belive, and a couple other sesnors that are slippin my mind, the fans spin.
Old Mar 12, 2003 | 05:23 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
where is this located ?
and also where is the EST located so i can reconnect that
Old Mar 12, 2003 | 05:43 PM
91Z28-350's Avatar
I don't know about TAs, but on camaros, the EST is near the passenger side strut mount.
The MAP has a vacuum tube on it's underside. It's a small tube that connects to a nipple on the plenum. Is the MAP electrical connector plugged in? The MAP is located on the passenger side rear of the plenum, on the side.
Once you got that all hooked up, unplug the negative battery cable for a minute or so, or remove the ECM fuse from the fuse box. That'll clear the codes, and start it up again.
I don't know what'll happen if the distributor is off a bit. Someone else may know.
Old Mar 12, 2003 | 06:01 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
overheating
where is the coolant switch ?
Old Mar 12, 2003 | 06:15 PM
91Z28-350's Avatar
Front of the block, under the IAC, which is on the underside of the throttle body.
Old Mar 12, 2003 | 06:20 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
well everything seems to be connected, the fan isnt turning on tho, i disconneted the neg side of the battery so i could clear the codes, so when i started the car the engine light wasnt on but my temp was rising fast so the car wasnt on for very long. how long would it have taken for the light to pop back on if there were new codes ?
Old Mar 12, 2003 | 06:41 PM
91Z28-350's Avatar
pretty quick.
How's your coolant level? Open up the radiator cap and take a peak.
Old Mar 12, 2003 | 10:11 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
coolant level is fine, fan dont turn on, and also i think my thermostat may be bad
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
