Overheating
Old Mar 14, 2003 | 02:36 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
Overheating
Ok, my car was overheating before, when it was just sitting there, at first i thought the fan wasnt working, but i just verified that it infact does work, then i thought ok maybe a bad thermostat, so i took the stat out and didnt put one back in to see how that did, it still seems to keep really hot, its a few line above 220, and i really dont think it should be that close, so i'm thinking i prolly have a bad radiator. any imput ?
Old Mar 14, 2003 | 03:37 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
ok i just realized i posted this in the wrong catagory and i apologize, but can somone answer me a quick question, would my car be runnin this hot at idle because of no thermostat being in ?
Old Mar 14, 2003 | 03:45 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Stock, If I recall correctly, the low speed fan turns on @220, and the high speed turns on it 230.
I just wired a manual fan switch, so I can turn them on whenever I want.
Old Mar 14, 2003 | 03:57 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
ok but my car when it idles gets pretty hot, enough to where my coolant in the radiator starts going nuts, i'm guessing part of that is because i dont have a thermo in there, so maybe is i put a 160stat in i'll be a runnin cooler rather then no stat correct ?
Old Mar 14, 2003 | 06:43 PM
Aron213's Avatar
Car: 88 Iroc
OK, first yes its not good for no T-stat because the water has no time to slow down in the rad. Next make sure that your fan motors are turning the fans with the proper load, just casue they are turning doesnt mean they are working fine. If you can get your hands on a laser temp gun, point it at your radiator and both hoses and see what your actual temps are, there should be at least a 10* temp difference between the two hoses.
Old Mar 14, 2003 | 06:45 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
well it turns out my fans dont even turn,,, do you have a picture of where the fan relay is located ? and how much it costs to replace
Old Mar 14, 2003 | 06:51 PM
Aron213's Avatar
Car: 88 Iroc
Not sure where they are on a TA, on the camaros one is down by the battery(pass side front)...they are the same relay as a MAF power or burnoff, cost about $15
Old Mar 14, 2003 | 06:59 PM
SydwayzTA's Avatar
Car: 1986 Trans Am
hmmmm i think i may know where its at, what does it look like
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
