Have a little problem with my new 52MM TB...someone help?
Old Mar 15, 2003 | 12:07 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Hey Guys, I bought a BBK/Edelbrock 52MM Throttle Body off of ebay about 3 months ago..I polished it and everything, it looks real sharp. THe guy said it would fit my 1991 Z28 Camaro (5.7 L98).....I was going to install it today....everything looked like it was lining up properly...but..the Throttle Cable....it is attached differently....from my stock TB. I beleive the guy sold me a TB off of an 85-88 TPI system...instead of a TB from an 89-92 system. My question is....can I get an 85-88 Throttle Cable so I can use this Throttle Body? Because my exsisting cable (89-92) will not attach to the 52MM TB. If anyone has ANY info....or has done this before...PLEASE let me know! Thanks alot!
Attached Thumbnails Have a little problem with my new 52MM TB...someone help?-bbk52mm.jpg
Old Mar 15, 2003 | 12:41 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
Yep, all you need is the late model thirdgen throttle cable. It's a simple swap! I was the opposite of you and had to switch my 91 to the old style cable.
Old Mar 15, 2003 | 12:44 AM
Engine: 5.7
Man! that is soo great to hear!....I paid $175 dollars for the TB...and I REALLY want to install it...so....can I just get the Throttle Cable at Autozone?
Old Mar 15, 2003 | 01:16 AM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
GM part# 14080202
About $20 from the dealer. Don't forget the clip that holds it in place, that's like $0.25 extra
Old Mar 15, 2003 | 12:29 PM
JMatlock88's Avatar
Car: 1991 Formula
Ya, it's definetly a junkyard or dealor-only part. Have fun!
Old Mar 15, 2003 | 01:46 PM
Bort62's Avatar
Actually, Napa Stocks it.
You know what - I have a 92 TB on my 85 and I am currenly using the early model Cable attached to the cruise control Nub on the late style TB
Would you be interested in trading cables ?
Shoot me an Email --> Bort62@speedtoys.com
Could work out for both of us
Old Mar 15, 2003 | 10:23 PM
Larry Dunlap's Avatar
Car: '91 Formula
Transmission: TH350 built
YOu can get a LOkar TPI throttle cable, it comes with provisions for each the old ( a round ring wiht a hole in the middle) and the new ( a metal cylinder that fits into a hole on the TB). It is braided steel and looks cool, but you have to get their bracket, and then you have to change the Transmission cable too, Its kind of pricey, about 150 for all three, but it looks good after. I did this, I will get a pic and show you
Old Mar 17, 2003 | 11:21 PM
Engine: 5.7
Well.....I've been talking with 5SIZ.....and changed his TB.....from an 85-88 to an 89-92....he says that the air idle passages are different.....and his car wouldn't idle at alllllll. Did you guys have any problems like this????
Old Mar 17, 2003 | 11:41 PM
5SIZ's Avatar
Car: 1987 IROC-Z
https://www.thirdgen.org/techbb2/sho...hreadid=167273
go here to geta better undertsanding as to where im coming from.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
