oil pump shaft
Old Mar 20, 2003 | 10:05 PM
David Culpepper's Avatar
oil pump shaft
ok need help asap its a metal oil pump shaft with the metal collar the collar does not lock into the pump like the nylon does is this right or is something a miss
Old Mar 21, 2003 | 06:27 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
It is fine, the metal ones are a slip fit. Once you distributor is in it is not going anywhere.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
formula_novice
Aug 18, 2015 08:48 PM
