DIY plenum porting question
Old Mar 21, 2003 | 02:23 AM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
Hi. I am interested in doing this and already have a dremmel but my question is what specific bit(s) do I need to do this job?
Old Mar 21, 2003 | 02:13 PM
BOTTLEDZ28's Avatar
Transmission: A4
you wanna use a a bit that doesnt have cross patterns on it. Get a single bit carbide grinding stone bit. that is what I used and it didnt take long to grind down the walls. it will not get clogged up as fast with aluminum chips.
Old Mar 21, 2003 | 08:02 PM
87GTA Runner's Avatar
Car: 87 GTA
I do quite a few of these and I prefer a metal cutter. Just make sure you use some kind of oil on it to keep it clean and it will cut faster.
Old Mar 21, 2003 | 08:08 PM
Car: 87 GTA
Old Mar 22, 2003 | 12:56 AM
bigals87z28's Avatar
Car: Check The Sig
i HIGHLY do not recomend that carbide stone thing... i got 2 of them and they were a waste... The thing you want is what looks like a can with little cutting fins around it... dip it in oil and let'r rip... sorry bottled.. but i had NO success with that carbide bit with the dremmel.. all it did is make things smooth... with the tin can with fins, it ate that EGR wall like a mad man... very impressed with that.. i had to go to Home Depot 4 times and almost get arrested to get these stupid things... but they look nice!! cant wait to get my pics of it almost done...
Old Mar 22, 2003 | 05:40 AM
Car: 87 GTA
This what you talking about Al, it's what I use.
Old Mar 22, 2003 | 05:42 AM
Car: 87 GTA
When I'm done with the cutter, I follow it up with a flapwheel sander. It makes it real smooth, a must if you ask me.
Old Mar 22, 2003 | 11:02 AM
Car: Check The Sig
yep.. exactly 87GTA... ive been using sanding drums to smoth it out.. but its polishing it! hehehe..
Old Mar 22, 2003 | 12:44 PM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
can someone post some pics of what has to be removed, i know theres something about an egr plate but stil kinda fuzzy, also what kinda gain should i expect
Old Mar 22, 2003 | 01:43 PM
Car: 87 GTA
Check out Vader's article.http://216.121.161.76/files/PlenumPorting.pdf
MantyZ28
16
Dec 21, 2015 11:02 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
mx127
Aug 10, 2015 08:13 AM
