throttle body swap
Old Mar 30, 2003 | 07:21 PM
zboss86's Avatar
throttle body swap
I'm not sure where I need to post this but here's my deal...
I've bought a LT1 throttle body for my 86 tune port.
before you ask, I bought it b/c it's a 58mm and I like the progressive throttle linkage that the LT1's have. And I also got it for a good deal.
Complications...
The two sensor adapters are different
-IAC adapter
-TPS adapter
-Throttle cable
-TV cable
I'm not worried about the throttle cable and TV Cable, I can may them work.
I don't know much about the IAC plug and the TPS plug. I may be able to swap the bottom piece with the IAC, I'm not sure. I don't know about the TPS.
Has any body done this before or can anybody help me?
Old Mar 30, 2003 | 08:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You must have one hell of a motor to be using a 58mm throttle body. If you're under, oh, 500 horsepower, you're going to find that the 58 doesn't improve performance and will most likely hinder it.
But anyway... there was a thread a while back that will answer your questions. Try doing a search. Somebody put an LT1 tb onto a TPI car. I believe the wiring for the TPS is the same, so you can just splice. I'm not sure what was done with the IAC, but I don't recall them being different.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
