Twin Turbo IN a Camaro
Car: 91 Z28
Hey guys, im thinking about putting 2 turbo's in my f-body. I have made a list of things i have to modify. But in need to have some input of what else i have to change. I.e computer and so fourth
this might not be the best place to ask this question, but im not sure... ill answer it with the what i know. Your gunna need bigger injectors, afpr for tunning, custom prom, and other tunning equipment. This would probably be best on the power adder board.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The entire motor needs to be built with turbocharging in mind. This means everything from the type of crank, to the camshaft, to the honing of the cylinder walls. Head selection, injector selection, programming, etc, all that crap needs to be properly chosen for your specific application. Like greasemonkey said, go to the power adder section, start reading your *** off, and do a bunch of searches. Once you get the overall flavor of what's involved, then you can start asking the specifc questions that will develop.
Terrell351
Jun 13, 2021 01:13 PM
