Who makes the best Fuel Pressure Regulator
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I've tried doing a search on who makes the best adjustable fuel pressure regulator but there hasn't been a clearcut consensus on who's is the best. I know there are a few out there, BBK, Crane, TPIS, Accel, Holley, Hypertech, etc. Your opinions on them would be appreciated.
Car: 04 GTO
Transmission: M12 T56
IMHO, there is a consensus. The holley is hands down the easiest to adjust. No tools needed, just an easy to reach and turn ****.
Functionally, all AFPRs are going to work the same. The difference is ease of adjustment. It takes me less time to set my fuel pressure then it usually takes the other folks i'm at the track with to get a wrench on the adjusting bolt for the first swing....
Car: '91 Formula
I'm very happy with my Holley unit. I wouldn't even want to try to get a wrench of any kind in that small of a space to have to adjust my fuel pressure. I love just being able to turn the thing by hand. The only downside to the piece is that you have to grind away part of the rear corner of the plenum to get it to fit right. I was able to put the plenum on just fine without grinding, but I wasn't able to turn the dial at all.
Car: 04 GTO
Hmmm, i didn't have to grind anything on my plenum. I don't even need to take my MAP or distributor cover off to turn the ****.
What year is your car. Maybe the early plenum is a little thicker in the back than mine. Or how bad is the interference. Is it just at the high end of adjustement. Off the top of my head i think i can get down to under 37psi, i forget if i was limited by running into the plenum or ran out of thread though....
Ed. Was it just temporary that the fuel pressure on the Holley wouldn't hold or was it something else.
https://www.thirdgen.org/techbb2/sho...sure+Regulator
Has the packaging of the Holley's gotten better in the past couple years?
Has anyone had to grind down there plenums a bit with the 89-92 style plenum?
Car: 04 GTO
My pressure still leaks down after i shut the engine down, but it doesn't actually cause any problems. It doesn't leak down so fast as to prevent a quick restart, and once the engine has been off long enough for it to go low, it will reprime on start up anyway.
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
I was going to get the holley unit but its not really all that difficult to braze... and if you screw up you were about to replace it anyway... Just a thought for all us cheap skates out here in the real world. http://www.gmtips.com/3rd-degree/dox/tips/afpr/afpr.htm
Car: 1992 Z28
Engine: 355
I suggest getting an AFPR that comes with a new diaphram. The Accel and Holley units include them but they also cost more. Just my 2 cents
Well I guess I'm going to buy a Holley one. Thanks for the info.
Car: '91 Formula
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I may be crazy but i cant find the P/N for the holley AFPR unit.
I will be using stock tpi for a while, then probably a stealthram or large tube runners later. will it still fit?
and where the heck is it? if i had the P/N that would help loads...
Car: I
Engine: Taunt
Transmission: Mustangs
My accel unit won't bring my accel gauge below 50 psi, even with the adjustment screw all the way out. The gauge read my stock pressure at 47 psi before I put the adjustable unit in, where I belive 43.5 is spec. Regardless of which is out of wack, I wouldn't suggest either. Go with holley.
Car: I
Engine: Taunt
Sounds like you have the spring under the diaphram in cocked or something, or maybe there were some shims under the stock regulator that you missed removing. I have an Accel regulator that I can back off to 0 psi without problem
Well, if you were to back the screw out all the way and install the regulator (like I did), then no, the cap didn't compress the spring as the screws were tightened.
If you take it back apart look carefully for any shims that might have been under the bottom end of the stock FPR.
92camaroJoe
Aug 13, 2015 06:07 AM
