Anyone running a 327 with HSR yet? ( I did a search)
Old Apr 24, 2003 | 05:48 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
I was just offered a fully built low milage 327 for cheap (dirt cheap)by someone that I know who knows everything that's in the motor. It has double hump heads (need the holes drilled for the accessory brackets). It also has the 2 x 4 intake that was famous on the earlier camaros. I could sell that to fund the project since I am on a budget.
I know first off this would not go well with the TPI . I had considered a Stealth Ram swap so this would be a good reason to go that route. I think the SR would like the 327's tendency to wind up. I was just wondering if anyone has done it yet and would like to get some feedback. I know some of you will say get a 350 which was my plan but I can't pass up this deal. It's either going in my car or I'll be saving it for another carbed car someday.
Old Apr 24, 2003 | 08:52 PM
rattlesnake_dm's Avatar
Car: 1992 RS (25 th Anniversary)
Engine: 350 Miniram XFI
Transmission: Pro-Built 4L60
Hi, I'm doing that swap too. I don't know what info I could give you, I'm learning as I go along. I've been told to get a 350 over and over, but I'm going to fuel inject my 327. Not giving up. From what people have told me, either the Accel/Lingenfelter Superram, Holley Stealth Ram or the TPIS Miniram will work. I have heard that the Superram can be a pain to install, so I'm not going that route. I am going to use the Miniram from TPIS. I've heard good things about it. I've heard good things about the Stealth too. They all cost money too. Also, heads....... I had "291" double/camel hump heads, no accessory holes. This was a pain. I talked to shops about tapping the holes and they said it could be done, but I might run into leaks from the holes. I talked to people about the holes and they said to just get new heads. Well I ended up getting new set of heads. I think any of those intake systems will perform well, just your preference.
Dustin
Old Apr 24, 2003 | 09:23 PM
IROC315's Avatar
Transmission: A4
Axle/Gears: 3:23
Glad to hear someone else is doing this.
The way I see it, anything is better than my 305 right now. It will make plenty of power and I can then take my time to build a 350 or 383. My brother was running 12s a few years ago with a similar built 327 in his 80 Camaro. Of course it was carbed and had a really radical cam.
I'll ask around about the bolt holes. The guy I know at the shop is pretty good, He might be able to help me figure something out. I've heard of simple brackets being fabbed up for this.
Old Apr 25, 2003 | 12:28 AM
Bjorn's Avatar
Car: 86-IROC Z28
Engine: 327
Transmission: 700 R4
I did make my own bracket for the generator on my setup. It was not very difficult. I used one header bolt and one intake bolt and wrapped a 1/4" flat bar around w. a nut welded on it to mount generator. No big deal at all. I do not have AC though.
/Björn
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
355tpipickup
Aug 19, 2015 10:02 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
355tpipickup
Aug 13, 2015 07:35 AM
