I havent got a code for the EGR yet after installing my HSR, is this good or bad? I am still running the stock chip with an Ed Wright chip 2 chip
I notice you are from massachusetts. A relocated MAT (a given with a HSR) can make the ECM not use the EGR unless you're in summertime like temps. You have to set the EGR enable temp (based on IAT) much lower to get proper function. No attempt at use, no code.
Also, 32 only sets under pretty specific circumstance. Like cruising at 50-60mph on a pretty level road for 5 minutes or so.
it should eventually peek its head out. mine did it on the first trip out after putting on stealth ram, didnt do it for another month, then i got a chip with injector constant changed, and no egr diagnostics
I did not relocate the MAT sensor. Ill get around to it when I can get a custom chip burnt for me
Quote:
Also, 32 only sets under pretty specific circumstance. Like cruising at 50-60mph on a pretty level road for 5 minutes or so. [/B]
Yep, that's exactly what mine did.
i also havent thrown the code....yet
